Transmission re-programming? Not reset!
Old 06-01-2017, 02:48 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Originally Posted by jlr82
My 2014 W204 shifts exactly the same way. The programming has been this way for a while. It's better in any mode other than comfort. I'm going to have the dealer update my software to see if it helps any, but since you guys are reporting the same pattern on the W205 my guess is it's by design and not something that will be "fixed".
its by design, to get the car up to speed and into a higher gear quicker for comfort and economy.
i hate it. I move the car to individual mode most trips where everything is set to comfort other than the transmission.
Old 06-01-2017, 08:35 PM
Lin Wei's Avatar
2015 C400 4Matic, 2011 S400 Hybrid, 2004 C230 Kompressor, 2000 ML320
I had the same issue and I went with the route of tuning the TCU. It worked well, but I think the OEM has continue to adapt the driving styles and the symptoms is starting to show again. I plan to so the same process again to see if the reprogramming (tuning) would make it go away again. My car is a 2015 C400 7G with 52000km on it. Canadian car. 😁😁
Old 06-01-2017, 08:57 PM
Former Member
removedCFGaccount's Avatar
CLS
Huh?
Old 06-02-2017, 08:05 AM
blizzard12's Avatar
2017 Mercedes-Benz C300, 2017 Mercedes-Benz GLC300
Update: I saw Ronnie yesterday. He really is a helpful guy. Even though I showed up without an appointment and without any kind of notice, he immediately went on a road test with me despite being super-busy.
Interestingly when he drove the car the transmission behaved as if it knew we had guests. Later I realized that we have slightly different driving styles, that is he was just a bit harder on the acceleration resulting in proper 1-2-3 shifting. According to him the transmission cannot be re-programmed to shift differently. At least not by the dealer. The only thing they can do is re-adaptation which is not quite the same. I guess I'll be okay driving his style that makes the transmission actually use the 2nd gear properly.
There's also some noise that seems to be coming from the suspension. Kind of hard to hear unless you know what to listen to. While another foreman at a different dealership didn't actually want to hear it and shrug it off as "normal", Ronnie did take the time and made the effort, and showed genuine interest in trying to help me.
Even though he might not be able to fix quite everything his approach shows that he wants to help you.
​​​​​​The guy is A+++!
Old 06-02-2017, 08:15 AM
Former Member
CLS
Well, I'd hoped for better but I agree, the guy has his heart in it.
Old 06-03-2017, 11:23 AM
applehaus01's Avatar
C300
Time to move to Canada. Getting bent over with no lube in the US.
Old 06-03-2017, 02:15 PM
  #32
Former Member
CLS
Eh?
Quick Reply: Transmission re-programming? Not reset!
