Will these rims fit?
First post here
Used to be pretty active on the bmw f30 forums
Just got a c300 brilliant blue sedan and I love it. I want to get new rims for it right away. I have no prior experience in measuring and hope to get your feedback. I was looking to get some VMR on my car
http://www.velocitymotoring.com/wheels/v710/
http://www.velocitymotoring.com/wheels/v803-6/
I like the v710 and the v803 and I would prefer 19" rims. Will any of these fit my car? What kind of tires would I run on these? I like the v12 hankooks but would have no idea what sizes to buy
Thanks in advance
Besides that: the engine is quite strong, very comparable to the 328/330i but the interior is on another level. Only gripe now is this annoying rattle that I feel coming from the rear of the car near the roof...which might be the panoramic? not sure on that. Next mod will be the dinan sport when I have time as well. I'll be active here too so thanks in advance!
I like the 803 rim - looks nice. Be sure to post a pic if the fit and you get them.
About to pull the trigger on the 18" vmr's
Should I run square or staggered? The 18's on standard run 225/45/18 front and 245/40/18 it looks like. I'm wondering if I go wider on the rears (maybe 265?)
Square of course you can rotate tires for longevity but would like some more grip on the rears. anyone go aftermarket wide and can recommend? Or is the w205 just better fit for square set ups? (my 17 is 225/50 square and it's quite nice)
choosing between hankook v12 and s1 noble. any input? Might as well have fun with the v12 lol
I got the wheel specs from this website:
http://www.modbargains.com/VMR-V710-...Benz-5x112.htm
Ask @Mike5215 for the tire sizes, but I'd keep them staggered (not square) and run close to the factory sizing.
You read my mind. Those are the ones I'm getting but in 18" size
The 710 in gunmetal. I want those "fill out" out so it eliminates the need to lower for the wheel gap.
So you recommend 18 x 8.5 et45 and 18 x 8.5 et 45?
Yeah I messaged mike already LOL
Previously I ordered square at 225/45/18 but with me going dinan, I want a bit more tire. Hoping to run 235/45/18 and maybe 265/40/18 or something. But I'd settle for stock 18" numbers 225/45/18 and 245/40/18 as a worst case scenario. I just think I can go so much wider based on what I see in person. Thanks!!
If you're going up in rim width one inch, that's an extra 25mm. Ideally you'd add 25mm to the tread section width (240 + 25 = 265 etc). But when you increase tread section width but keep the same sidewall ratio the actual height of the sidewall increases.
So you have to finesse the numbers a bit to go wider, but keep close to the same sidewall height, and of course the number you come up with has to correspond to a tire someone actually makes.
Visually I think a sidewall that isn't stretched but also isn't bulging looks best, but that's really an aesthetic concern.
Got the 18" VMR 710 installed and I love the look
Got it installed with the Hankook S1 Noble 2, known for street performance, not as sticky As the hankook vs2 as I wanted something as close to stock so I could keep the comfort of the ride I had in the base 17". I highly recommend this tire! Might solve many of your issues I see with the 18" wheels. Ride is just as comfortable as the 17". $120/tire installed/balanced and comes with the 45-50k thread guarantee as long as you rotate. Cheap investment compared to Michelins. Here's a quick pic. If you want more pics at different angles let me know
By all means share more pics.
Did you go with stock tire sizes (widths)?
