Put in 10 inch sub under trunk
Old Jun 24, 2017 | 04:05 PM
Stefan-c300's Avatar
2017 c300 sedan
I got professionally installed a 10 inch sub, the vpas10, where the spare wheel would go if the car had one. On my base audio system it is night and day difference in sound quality. Install took less than an hour and cost 740$ Canadian all in. Very very pleased with the results. Fits perfectly.
Lifting the trunk floor
Old Jun 24, 2017 | 04:37 PM
Mike5215's Avatar
2016 C300
Nice! Add a set of tweets up front and you'll be golden.
Old Jun 24, 2017 | 05:41 PM
2017 c300 sedan
Originally Posted by BareQs
Was this in Toronto by any chance?
Close! It was Aurora, done at The Noize Boyz
Old Jun 24, 2017 | 07:38 PM
noornaseri's Avatar
2016 C300 4Matic
do you have a link to their site, im definitely in need of a sub as well and that setup looks perfect
Old Jun 24, 2017 | 08:13 PM
2017 c300 sedan
http://www.noizeboyz.com/index.htm
Old Jun 26, 2017 | 01:28 AM
DBOC205's Avatar
W205 C250BT
Neatly done. Do you get any rattling with the interior floor lid or do you bolt that down somehow?
Old Jun 26, 2017 | 07:25 AM
2017 c300 sedan
The floor rattles a bit when the trunk is open, closing the trunk fixes it mostly. While driving on some songs when its extra heavy base I'll hear a little bit of rattle. Keep in mind this is a little sub, it doesn't shake your windows. With all the doors and windows closed, not a lot of sound leaks out, so I can still discretely blast my music and not draw attention.
Old Jun 26, 2017 | 09:53 AM
Mike5215's Avatar
2016 C300
The 205's trunk floor is actually a plastic tub (which I discovered after mine was badly rear ended) so it might be worthwhile to pull everything out and lay in some Hushmat or Dynamat deadening material in there and up and over the frame rails and out to the quarters. (basically the whole trunk floor). It'll kill the rattles and tighten up the sub's sound as well.
Old Jun 26, 2017 | 02:18 PM
auditoamg's Avatar
C63s
Mike - any suggestions for those of us that have all their electronics back there??? My trunk floor looks like a miniaturized computer server room. I would like to clean it up, but don't want to tear things totally apart, if avoidable.
A2A
Old Jun 26, 2017 | 02:53 PM
Mike5215's Avatar
2016 C300
Yeah, unscrew the audio rack from the floor and rotate the whole assembly up and out of your way. Shouldn't be necessary to disconnect any harnesses but they're all quick connect if you do.
Old Jun 26, 2017 | 06:02 PM
auditoamg's Avatar
C63s
BTW - did I mention that when I did my version of your "Audison" upgrade, we found a giant zipper back there, underneath the rack and slapping around on the metal body???
LMAO!!!!!!
Yeah, some German dude f'd up his hoodie during assembly of my car.
Old Jun 26, 2017 | 08:31 PM
Mike5215's Avatar
2016 C300
Ha. Well if it was a C300 sedan sold in the US, some guy in Tuscaloosa Alabama left part of his hoodie in your car. ðŸ¤
Old Jun 26, 2017 | 09:34 PM
auditoamg's Avatar
C63s
Nope, Coupe built in Deutschland... LOL
Old Jun 26, 2017 | 09:57 PM
Mike5215's Avatar
2016 C300
Well that is weird. You'd almost expect that kind of thing in Alabama.
Old Jun 26, 2017 | 11:24 PM
auditoamg's Avatar
C63s
LOL... Yup!
Old Jun 27, 2017 | 03:17 AM
Jesbran Silva's Avatar
2014 C63 AMG Sedan | 2014 E350 Sedan
Mike,
Looking to add this Cerwin Vega set up but What do you recommend for a tweeter upgrade? I'm absolutely new to audio upgrades.
Currently have the Burmester surround sound.
Old Jun 27, 2017 | 07:34 AM
Mike5215's Avatar
2016 C300
I'm not familiar with Cerwin Vega car audio. They do make good pro-sound (PA gear) for bands. I'd recommend the Focal KRS100 K2 Power 4" component two-ways. The 4" in that set is decent but the tweets are really nice. They were originally $700 for the set but I've seen them new on EBay for half that.
Old Jun 27, 2017 | 12:14 PM
2017 c300 sedan
Originally Posted by Jesbran Silva
Mike,
upgrade just the sub first, and then turn down the base into the equalizer settings to take the bass off the little speakers. You will notice improvement in sound quality. I'm not an audiophile so this is great for me.
Old Jun 27, 2017 | 02:09 PM
auditoamg's Avatar
C63s
The only issue with this approach is that you also turn down the amount of bass/change the frequency response of the car to the new subwoofer. In other words, it turns EVERYTHING down, including what the new sub replicates/produces.
Ideally, you want flat to the speakers and then boost bass from there, otherwise you are cutting mid-bass and overall frequency curve of the car.
That being said, if you like the sound that way, then great!
For me, the only solution as to eliminate the extra bass going to the OEM speakers and route that to the new sub, using a new, external, non-OEM crossover device (i.e., a DSP device or an Audison).
A2A
Old Jun 27, 2017 | 05:05 PM
Mike5215's Avatar
2016 C300
Yeah I agree. The car has the mids handled sort of, but it needs the mid bass, low bass and ultra highs. I think you need the sub plus the tweets to fill it out.
I'm also thinking a shallow mount under seat sub like that is ok down low but not great for mid bass. Hard to say without hearing it.
Old Jun 27, 2017 | 10:32 PM
auditoamg's Avatar
C63s
I was going to say the opposite.
Low, clean, smooth bass requires tremendous amp power, and usually a decent amount of speaker excursion that lower profile solutions just don't offer, in my experience.
I have a low profile, TS series JL now that will NEVER compete with my Boston Acoustics 505 race track sub that would take up 1/2 a trunk and 1000 watts easy!
LOL
Old Jun 27, 2017 | 11:05 PM
Mike5215's Avatar
2016 C300
Yeah I had one of those underseat amps and all it was good for was the "hit", almost like a transducer. Couldn't play higher. My idea of mid bass is best reproduced by good old fashioned 6" woofers low in the doors.
Old Jun 27, 2017 | 11:09 PM
auditoamg's Avatar
C63s
Same here, from a mid bass perspective.
I used to bolt transducers to my couches for movie watching and a split off the LFE output.
Old Nov 5, 2017 | 04:17 PM
o27's Avatar
o27
Mercedes S205 220d Edition C
Is it possible to add tweets i.e. the std. MB Burmester/HK tweets without cutting into the existing wires? Haven't seen any for sale with the connectors?
