C300 Turbo Upgrade - Partner Needed
#252
SPONSOR
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Ah, that makes sense. Nice!
In reference to your 300whp - is that just tune and turbo or does that include the downpipe, etc?
Also kind of general - won't internals need to be upgraded after about 350whp? Something's bound to break...
#254
SPONSOR
The customers that are hitting 300WHP, have turbo back exhaust, intake, turbo, tune and water meth.
#255
Upgrade
just wanted to say thank you to turbokits as I received my armytrix valvetronic exhaust and Catless downpipe as well as the water/meth kit from them today for my C300
Just waiting for their upgraded turbo to show up then I’ll have it all installed and it’ll be going to AMR after that for the tune
so we should have solid documented tune and power numbers by the end of November
right now I’m running a jb4 beta tuner setup on map 2 and it’s definitely faster than stock ..but I haven’t had it dynoed so I’m just going by my butt dyno
I can’t wait to see the actual numbers after this upgrade!
#256
SPONSOR
#257
Pre upgrade dyno numbers
just an fyi for anyone interested
I had my c300 on the dyno today and with the stock tune I put down 192whp
the only upgrade is the burger tuning cai
with the jb4 beta tune on map 2 ( most aggressive) tune it put down a whopping 198whp
a whole 6hp more with the jb4...lol
700$ for 6hp doesn’t seem like such a good deal
#260
well considering theres only 1 plug to plug in and the Bluetooth obd2 setup I’m not sure what I could have hooked up wrong?
its certainly showing it’s running map 2 on my app
#261
Upgrades installed
The new turbo/downpipe/exhaust and meth kit were all installed today. Pretty straightforward install..no hitches or gotchas
the meth injection install is tight and we had to remove the intercoller to do it properly..but everything is in
i have an appointment with amr tuning on November 26th to let them do their magic ..and then we’ll see what the results are
TurboKits.com (11-18-2018)
#262
Turbo upgrades without water meth?
hi turbokits, I am wondering is it ok that we do not install water meth? How will it perform without water meth? How many whp? Is all the stock Internal component able to support this upgrade?
#263
SPONSOR
You do not have to install water meth, but you will not be able to run the higher boost levels the turbo is capable of flowing. So you would leave HP on the table.
#264
hi everyone,
just want to share dyno result after upgrade the turbo
so the specs are,
the turbo upgrade from turbokits
Armytrix full exhaust system
stage 2 tune by our local tuner
so the number are
Power : 246.89 WHP
Torque: 435.98 Nm
and also this is the log from my local tuner
still waiting for the AEM WMI kit and some upgrade with the air filter system
will post dyno result after all the kit come
thank you
so the specs are,
so the number are
Power : 246.89 WHP
Torque: 435.98 Nm
thank you
#265
Upgrade
are you running the armytrix Catless downpipe?
if so any check engine lights?
what air filter upgrades you doing?
i have the burger tuning CAI
mine is going in in for the tune Monday
#266
air filter will be using something like arma “carbon air filter” but it still on the way
#267
Downpipe
thanks for the quick response
do you have any check engine lights with the Catless downpipe?
i just had all mine installed and haven’t driven it at all til it’s tuned
just curious if the 02 sensors are throwing a code
#268
because my check engine is off (normal)
#269
TurboKits.com (11-24-2018)
#273
Upgrade -
Update for 11-27-18
I dropped my c300 off at AMR tuning in Danbury, Ct yesterday for the tune.
If you are in the New England area and you're looking to have some tune work done...then AMR is the way to go. When I walked into their shop yesterday they were working on a pair of new c63S with upgraded turbo's and tuning putting down around 900HP/1000+ Tq
The owners personal car is a new 2019 e63 with a custom tune only and is putting down over 800Hp/1000+ Tq - Talk about a beautiful car...
I feel VERY comfortable that they will tune my c300 to an optimal level - just need to wait a few days to see what the result will be !
thank you Turbo kits for hooking me up with such a great tuner
DIVINE AMG (11-28-2018)
#274
SPONSOR
Update for 11-27-18
#275
It’s getting close
C300 almost done with the tuning !
BIG thanks to Jesse at turbo kits and AMR tuning
TurboKits.com (12-12-2018)
