Converted C300 to C400/C43 exhaust tip
Old Aug 18, 2017 | 01:12 AM
xclream's Avatar
R350
As titled:
Old Aug 18, 2017 | 04:10 AM
guhvies's Avatar
2017 C43 AMG Saloon
Did you consider going the C63 tips route or were you thinking about doing the barest minimum to get you a look you liked?
Old Aug 18, 2017 | 07:35 AM
Gungaslow's Avatar
2017 C43 sedan
That's cute!!
Old Aug 20, 2017 | 09:46 PM
xclream's Avatar
R350
Didn't think about C63 at all, too aggressive for my taste, just wanted that simple factory look, and still different from the normal C300. If you know what I mean.
Old Aug 20, 2017 | 10:20 PM
Gungaslow's Avatar
2017 C43 sedan
Are those the stick on type?
Old Aug 20, 2017 | 10:25 PM
xclream's Avatar
R350
Yea, used high-temperature glue to ensure that it stays on. 3M double-sided tape alone won't do it.
Old Aug 23, 2017 | 09:35 AM
S18LOK's Avatar
W205 AMG Auto Saloon-Prem Plus-Privacy Glass
Do you have the link where you purchased theses from? Please
Old Aug 24, 2017 | 07:13 AM
xclream's Avatar
R350
Yea I do. Here you go, good luck.
https://world.taobao.com/item/550159...45c5a63fQIAQc7
Old Aug 24, 2017 | 11:22 AM
S18LOK's Avatar
Originally Posted by xclream
It's ok i understand Chinese
Thanks!
Old Aug 26, 2017 | 12:13 PM
almalave's Avatar
GLC300
Caution!!!
I ordered those from eBay. Came fron China. i thought I might give them a try since they were only 20 bucks. They came with their own adhesive strip. Looked really good for about 4 days. Then it was a mess. Apparently (it happened after I drove the car while raining) the adhesive could not handle the heat and started dripping a yellowish brown residue which then hardened. had to take the whole exhaust tip out and after a couple of hours trying different cleaning agents and then polish (with a lot of elbow grease) it finnaly came out. Here is a pic of the right side but the left side was worse.
i don't know if this could happen to you.
Attached Thumbnails Converted C300 to C400/C43 exhaust tip-img_1174.jpg   Converted C300 to C400/C43 exhaust tip-img_1175.jpg   Converted C300 to C400/C43 exhaust tip-img_1176.jpg
Old Aug 27, 2017 | 05:53 AM
xclream's Avatar
R350
You need to make sure that you use high-temperature adhesive to glue on. The glue I used can withhold temperatures up to 250C, and it was clear like silicone, so I've had it on for over a week now, with no issues.
