Solved: black ash center console replacement with inactive clock
Old Jul 21, 2018 | 04:05 AM
TorbenK's Avatar
C220D W205 Estate
Old Jul 21, 2018 | 05:52 PM
Sam Manuel's Avatar
c class
What am I looking at ? I bought the wrong black ash console since I have no clock and got too lazy to return it so I feel like I gotta make it work .
Could you give me a little detail on what you did in the pictures?
Old Jul 21, 2018 | 06:11 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Looks like they replaced the clock face with an AMG Badge. You can find those clocks on EBAY. Some start bidding pretty low in price but most are over $400. Why was the clock inactive?
Old Jul 22, 2018 | 01:42 PM
TorbenK's Avatar
C220D W205 Estate
Well as a lot of people I've bought the black ash console which comes with the analoge clock.
It's bought second hand, so I got the instruments as well.
From this forum, I've experienced that connecting the clock is a b****h if it is not already OEM installed.
Therefore I looked for a second best solution.
The emblem was quite cheap.
AMG emblem from wish
I've also ordered another non AMG badge that I want to fit instead. The fit is perfect.
Mercedes Benz emblem
Old Jul 22, 2018 | 01:45 PM
GreekUPS's Avatar
Great idea BTW.
Old Jul 29, 2018 | 03:41 PM
TorbenK's Avatar
C220D W205 Estate
Old Jul 29, 2018 | 04:09 PM
GreekUPS's Avatar
Old Jul 30, 2018 | 06:50 AM
AMG C43 3LV6's Avatar
AMG C43 3LV6
Just curious could the clock be fixed or replaced? Or is that not possible?
Old Jul 30, 2018 | 11:58 PM
TorbenK's Avatar
C220D W205 Estate
As far as I know it needs to be connected to SAM and coded at a dealer
See this threat
Center console 95% done
Old Aug 5, 2018 | 02:40 PM
Allex1's Avatar
w205
Have you seen this? https://mbworld.org/forums/audio-electronics/662171-front-sam-wiring-diagram-w205-not-fuse-diagram.html
It's actually pretty easy to connect and works without dealer intervention.
Hope this helps and you can undo this questionable dyi.
Old Aug 5, 2018 | 04:11 PM
TorbenK's Avatar
C220D W205 Estate
I had not seen this.
Thank you very much. I will look into it
