c300 (w205) Plug & Play Full LED Headlight Conversion
I set out in search of LED headlamp units to replace the whole fixtures but was only able to find used MB factory LED lights which won't work with the stock halogen models without some extensive coding. I gave up and just settled for LED bulbs set up. That only lasted 8 months until the itch came back around after seeing several w205 models driving around with the LED headlamps. I had to have them. I went on eBay and my prayers were answered!
I found a company called Otto Auto selling plug & play full LED conversion fixtures with everything needed for $1,300 USD. I was stoked!! I thought it might be to good to be true so I had several conversations with them before making the purchase. I felt comfortable with it being through eBay and having the buyer protection so for some reason I was being scammed, it would be okay. I paid the $1,300 USD and waited anxiously for UPS to arrive for 5 days.
Just pulling them out of the box to inspect them, I was impressed with the quality and craftsmanship that went into making these. They were pretty spot on appearance wise. Now came the more difficult part, the install! I am by no means an auto expert or anything so I had been nervous about trying to do this myself but I wanted to give it a try because it seemed do-able. I was pretty surprised at just how easy it ended up being to install both fixtures. Took about 2 hours to do both, minus the rookie move of dropping a few screws into the skid plate under the car. After everything was cleaned up and put back, I tried them out and was beyond impressed at the appearance. It was an instant facelift for my car! The DRL start up blue then turn to the bright white light, just like the high end Intelligent Lighting System (ILS). The blinkers were bright and the headlights were beyond bright! The only things that were different between these and the real ones from MB is the real ILS will throw light in the direction you turn the wheel, whereas these are stationary but still wide angle. The ILS will also have both low/high bulbs on at night but the sensors and cameras will have them adapt to their surroundings so oncoming drivers are not blinded, whereas these lights function like normal low/high and the high bulbs are only on if you turn them on. Those are not a big deal to me because to install all of the cameras and sensors and go to MB to have the real ILS installed, that would cost a small fortune ha.
After using them for 2 months with no problems, my right blinker stopped working. I thought maybe a wire was loose so I tried unplugging the unit and replugging it back in. This didn't fix it so I emailed Otto Auto and they informed me that it sounded like I had a bad control unit. They sent me a new control unit to install immediately. The next day I noticed that the inside of the headlight fixture was filling with moisture and developing condensation internally as well as my DRL flickering bad. I emailed Otto Auto again to inform them of this issue and they were very helpful. They told me to return the control unit they sent once I get it because they are sending me a whole new right headlight fixture. All they asked is that when I install the new light, to remove the old control units from the previous fixture and send them to the office for inspection.
Easy installation again and the headlight worked perfect! No more issues at all. When I removed the old control units, I noticed that 1 our of the 3 units was corroded bad on the inside. Upon further inspection, the seal to the headlight had separated in a spot which caused the headlight fixture to fill with moisture and that caused the control unit to short circuit. It was one of those rare fluke things because my left side headlamp has given me no problems at all and is still perfect!
I am very understanding that things happen and Otto Auto is on that same page. They were beyond helpful and willing to do whatever it took to make this situation right and find out what went wrong. That said a lot to me about how they value customers and conduct business.
All of that being said, if you are wanting to upgrade your stock halogen light fixtures to the awesome and attractive LED models, Otto Auto is the way to go! The plug and play simplicity of their product, perfect appearance, spot on functionality, and proper customer service makes this worth every penny! They have actually dropped the price down to $1,200 USD so it's an even better deal. This is just one happy customer trying to give a fair review to anyone else that was stuck in the same spot as me with the halogen lights.
Otto Auto on eBay
Before w/ Stock Halogen
No Lights
DRL
Low Beams
High Beams
Low Beams
Low Beams
Low Beams
Hazards
High Beams
High Beams
High Beam
Faulty Control Unit
our product link is : https://mbworld.org/forums/c-class-w...otto-auto.html
Link to Depo full LED tails:
https://www.ebay.com/itm/Fits-15-18-...ry!91605!US!-1
for quite a bit cheaper. For instance this store assures me this is drop in replacement from original halogen headlights. All LEDS included etc. https://www.aliexpress.com/item/32898065133.html for US $1,037.40. I sent him pictures of my headlights to confirm.
My main concern is that the one from otto auto, as well as all of these other ones are missing the side reflectors that come on the American and Canadian cars. Circled in the picture I attached.
Isn't this kind of like, illegal? I know its not required for EU or Asian driven cars....but in America im pretty sure you're supposed to have them, right?
I tried finding a phone number for Otto auto but didn’t find one so I emailed them twice but no reply..
does any one here knows which controller I should get? Or if it’s actually a controller issue?
thank you!!
thank you!!
Can you tell me where I can buy these lights, I searched on AliExpress but found nothing, I live in Northern Ireland, and I can't buy anything here.
I will be grateful for your help . Regards
I pickedup Beamtech 1:1 .Ill try to install today 6500 K 12000LM 60W Xenon White Halogen .I understand the 1:1 bulbs are quite easy to replace!.Thoughts? Yes I understand this is a older thread.
Thank You in Advance
Lee
