Rollbar 2017 Mercedes C300 W205 convertible after deployment roll bar
Old Sep 3, 2018 | 09:53 AM
kalaemu's Avatar
2017 C300 convertible W205
Hi! How to lowered rollbar on 2017 Mercedes C300 W205 convertible after deployment ? Please Help
Old Sep 3, 2018 | 10:10 AM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Just a guess but I would assume it’s a major job that will require dealer or expert body shop involvement....if it can be safely done at all.
Old Sep 19, 2018 | 06:21 AM
kalaemu's Avatar
My solution below Even the Mercedes dealership didn't know how to do that.
Old Sep 20, 2018 | 01:20 AM
fabbrisd1's Avatar
A gaggle of MB's
The real safety question is if the deployment system for the rollbar is "one-shot-only" and if that needs to be replaced too - or you might be **** out of luck if there is a next time and it DOESN'T deploy.
If you are in the US contact MB Customer Care - and as a safety issue with your VIN# they WILL respond with correct info after they do engineering research
Old Sep 21, 2018 | 03:23 AM
kalaemu's Avatar
Without release the roll bar you can't close the roof top and remove the roll bar. You need to replace roll bar becouse is deployed no question abou that!
How to roll bar release mechanism looks inside see picture below
Old Sep 21, 2018 | 08:53 AM
Mikey53's Avatar
Veteran: Air Force
So, was the car actually rolled? What caused the bars to deploy?
Old Sep 21, 2018 | 12:06 PM
JAMADOR's Avatar
2015 C300 Sport
Seem crazy that it would be a 1-time use bar.
Didn't the R129/R230 have an auto-deploy roll bar that could be retracted?
I recall a friend having the bar deploy on his SL in a hard (aggressive) turn & there was a method to lowering the bar.
Old Sep 21, 2018 | 02:55 PM
fabbrisd1's Avatar
A gaggle of MB's
Whether the roll bar for a particular model is "fixed" or "extendable" (so at better starting height when top is open) is not the issue - the issue is if the roll bar is triggered to "highest safety position" by the safety system which often is triggered by a "one-time-explosive-extender" - the question becomes for safety reasons do you need that "trigger" replaced to restore full safety to your MB.
Good luck !
Old Sep 22, 2018 | 07:18 PM
kalaemu's Avatar
My car had a small accident. See pictures below.
Old Sep 22, 2018 | 07:24 PM
kalaemu's Avatar
Good luck !
It's one time deploy roll bar. Now I have to buy 2 x rollbar and dashboard who cover the rollbars. See pictur below.
Old Apr 2, 2020 | 06:16 PM
tjp74's Avatar
2019 C43 Convertible
A newbie here... sorry to dig up this 2+ year old thread but just got a 2019 C43 with roll bars deployed due to light accident. With top up that is... so I have an exact same issue with OP.
So... has anyone figured out how to push the roll bars back in? short of just cutting it? rear seats are also locked and won't open and top wouldn't move either...
Old Apr 5, 2020 | 09:44 AM
Rs3jay's Avatar
C63s edition 1
W238 e class rollover
Any one can shed light how to get the bars to back down. I done it before but forgot. Has a pin you either pull up or down to release lock some how?
Old Apr 7, 2020 | 05:33 AM
kalaemu's Avatar
Pull up small pice of metal covered by small plastic from rear cover dashboard about half inch up and the roll bar will released
Old Feb 3, 2021 | 07:31 PM
Bennyamg's Avatar
C63
Hi Kalaemu thanks for your great post, can you please explain how to push the roll bars back down as I have the same problem, I know you say pull up small piece of metal covered by plastic but I can’t see the metal you’re talking about? Do you have a pics that’s could help explain? Your help would be so appreciated.
Old Apr 1, 2021 | 04:20 PM
A O's Avatar
A O
c300 2018 convertible
did you figure it out ? I can tell you where the release ring you can call me but I am not able to release it still even after I know where it is it’s hard to get to 7027246013
Old Nov 12, 2021 | 06:49 AM
rangy's Avatar
250d Blue Tech sport C Class 205
I dont see any pics from others,i only see one pic of the roll bars up on first post? anyway what was the solution to this,it just seems to have gone dead, that usually happens when someone ask s about a thing,we all chip in our thoughts,then they discover how to fix it but forget to come back and tell all who was helping how it was done ha
Old Nov 12, 2021 | 11:56 AM
rangy's Avatar
The roll bar does need replacing, hey can be put back down and clicked into place,but the detonators are blown and may not work again,merc put mines down £150 labour, will replace them another day
Old Feb 18, 2022 | 10:15 AM
rangy's Avatar
Here is the solution to release the roll bars and push them back down, nyoud need to go to a dealership or remove or renew them £240, they are a one time deploy, but can click back into place till you decide to change them over and lets you use your roof for now, merc £150 to do this
there is no squibs/detonators/actuators to replace, you pull up on the square ring in the photo and it will release the tension and manually push them back into place hearing a click
they will leave a stretch mark on your roof material
photos below to show you where the pull ring is
how the bars look out of the car
part number
close up of square pull ring
how it looks without the rear dashboard shelf cover
pull on No. 2 and it releases the tension and allows you to push down and reset them back into place, but they will have to be replaced at some point
Old Feb 18, 2022 | 06:37 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
oh it's a convertible.
Old Mar 23, 2025 | 10:30 PM
youssay's Avatar
2020 mercedes c300
hi where is the solution dealing with the same problem , rollbar deployed while convertible down
