Highway vs city driving?
If the city miles are urban then yes.
City miles represent 2-5 times the the amount of running hours on the vehicle.
Think of it this way... the motor is just as happy running at 2500rpm in 1st gear as it is in 9th. But in 9th gear at 2500rpm on the highway, you'll be covering many more miles in 1 hour of driving than you would in the city.
Another obvious consideration is acceleration and stops.
City miles and dense traffic are always harder on a car than hwy cruising is.
However, most cars are driven mixed mileage and usually when someone claims that it's all hwy miles that person is lying.
Most new engines are broken in at the factory. Run in period is primarily for the rest of the drivetrain components and is not nearly as big a deal as people think. A MB passenger vehicle is not a sport bike. I go easy on new vehicles for the 1st 500 miles but I never baby them.
Something that I think is waaaayyy more important than the break in period is to always avoid wide open throttle before both the oil and coolant are up to temp. The ECU in a modern MB will try to keep you from being stupid but it may still be possible to redline it cold if you are manually shifting. I won't let my MBs run over 4000rpm until the oil is up to temp. Sometimes I need to manually upshift the 9g in my GLC43 because it loves to hold 2nd. Once the oil is up to temp I'll bounce off of redline without a worry.
Many new engines are trouble prone and no engine will last forever. Most modern engines are way more reliable than engines from 10 years ago. And don't forget that 25 years ago, 100,000 miles used to be considered the end of the service life for a motor and that was when you were expected to either rebuild it or be prepared for major failures like exhaust valves or head gaskets. Modern engines are more complex AND more reliable.
In the city , the engine is constantly being pushed from idle to high rpms and back again ,whereas on the highway its generally just cruising at around 2,000 rpm. Also the brakes and transmission are being activated way more in the city . This is also reflected in the fuel usage which can be as much as double in the city . All things being equal I would rather buy a highway driven car than city driven .
