Retrofit 2019 Ambient Lighting
Old Dec 11, 2018 | 10:22 AM
jeezus's Avatar
GLE350
Has anyone found out if you can retrofit the ambient lighting from the 2019 in other W205's? The interior structure looks the same where the lights are located. I'd imagine the software would just need to be updated.
Old Dec 13, 2018 | 02:39 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
its not there, the center is easy to add - the doors not so much.. lastly, you have to program the option in.
Old Dec 14, 2018 | 01:33 PM
jeezus's Avatar
GLE350
I wonder if its something that a collision shop could do for cheaper.
Old May 12, 2019 | 12:49 AM
rogilio's Avatar
2018 c300
Be very careful with these aftermarket kits. First, this will void your MB warranty. Second, you run the risk of crashing your Command Center software causing a significant cost at a Mercedes dealer to reinstall.Not sure why anyone would take the chance of downloading a Chinese patch on a German engineered piece of software. Definitely not worth the risk IMO.
Old May 13, 2019 | 12:30 PM
jeezus's Avatar
GLE350
Not looking to use aftermarket kits. I want OEM. But I'm wondering if the lights can be retrofitted.
Old May 13, 2019 | 01:37 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Because "German engineered piece of software" never has bugs or issues?
Old May 13, 2019 | 03:31 PM
rogilio's Avatar
2018 c300
Why add fuel to an already burning fire.
Old May 13, 2019 | 03:34 PM
benzdude's Avatar
Top Answer: 1
The fire you started? You are just going around cutting and pasting the same uninformed comment over and over.
Old May 13, 2019 | 04:55 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Did you have an issue with yours, first time I’ve heard of a problem with this.
Old May 13, 2019 | 07:11 PM
rogilio's Avatar
2018 c300
Yes, the OBD didn't download the software properly. Took it to an MB mechanic and he read me the riot act. Told me if MB found out, they wouldn't honor the warranty.
Old May 13, 2019 | 07:27 PM
GreekUPS's Avatar
Thanks for the heads up.
Old May 14, 2019 | 03:26 AM
mercedes.fan's Avatar
2019 E200 sedan
Probably cheaper in the long run to sell your car and buy one with the options you want.
Old May 17, 2019 | 10:26 PM
gtnotoriouz's Avatar
2016 C300 4matic
Can you be more specific? Where did you purchase the OBD and what year car did you use it on?
Old May 18, 2019 | 11:54 AM
rogilio's Avatar
2018 c300
Yes, I purchased from Amazon, and it is the type of OBD that uses a WeChat link to download the software. I believe that there is also an OBD that is self-contained that does not need a WeChat link. Used it on a 2018 C300 with Audio 20.
