Carfax, wrist pins and questions
On my Carfax, you can clearly see that all service was done on time and properly by MB in Roslyn, NY. But at 11/07/15 with 3919 miles, there was an entry for Maintnence Inspection Completed, no other info.
On 12/03/2015 at 4290 miles, the entry states:
Maintenance inspection completed
Transmission removed and reinstalled
A/C Receiver/dryer replaced
Engine removed to complete repair
Battery cables replaced
Engine checked
Electrical sysem checked
A/C refrigerant charged
Alignment checked
Wheel(s) replaced
Is this a safe bet that the piston wrist issue was taken care of early on? Is thi9s what I should see on Carfax as a correction for that problem? Car is smooth and not hint of wrist pin noise at all.
Any ideas?
How do I find the engine number?
I agree with one of the other comments here: take it into your local MB dealership to have it checked. You will need to leave it overnight so they can check it during a cold start because you can't hear the problem with a warm engine. Good luck!
Yeah, in my recent, limited MB experience, I do not see any other obvious reason that the engine and tranny were removed, but I think I will give the dealership a call Monday.There is zero noise upon cold startup right now, even in cold weather. Just wish it was better documented somewhere.
Every car model has their idiosyncrasies. For my Vettes it was the harmonic balancer. That was an issue for about 15 years on the earlier LS motors. But this time I have no documentation on what was done other than the Carfax.
