Black Plastic Panel Behind Door Panel Removal?
I tried removing the outside door handle but there no way to get the led out, it’s mounted on the inside and there is a small piece that sticks out with the led on the end of it. The first door took me 2 hours, the 2nd one took me 20mins. You have to loosen the window from the track, tape it up, push the black panel over then you can get to the led
Driver Side LED's front and back
https://www.mboemparts.com/oem-parts...amp-0998200183
Passenger Side LED's front and back
https://www.mboemparts.com/oem-parts...amp-0998200283
After the LED change the keyless entry does not work on the Right hand side of the car and keyless start does not detect the FOB.
Has anyone experienced the same issues ?
Last edited by akerlie; Nov 25, 2019 at 11:48 AM. Reason: Edit : Found it, forgot to plug in a plug
I had three LED replaced under warranty, but the drivers door handle LED has failed again (about 2 years on from the original replacement under warranty)
two weeks after this both of my puddle lights under the mirrors died. Swapped those out in about 15min each.
