Ambient Illuminated Burmester Mid Speaker Covers DIY
https://www.aliexpress.com/item/Car-...004674123.html
I did the rear doors first.
1. Remove the rear door trim (PDF attached)
2. Remove the upper trim piece from the rear door trim. (PDF attached)
3. Remove the adhesive residue from the current speaker cover catch hooks and loosen it gently with a screwdriver at the four corner tabs.
4. Install the new speaker cover.
I added some soft adhesive rubber (amazon) to the four corners before installing the new cover (to prevent vibration noises at high frequencies)
....and also some hot glue to keep it solid.
5. Tap your wires and add JST connectors. (on aftermarket harness: brown = ground, white = blue color 12 volt, orange = orange color 12 volt)
6. Re-install everything, test and enjoy.
By the way, I appreciate someone taking the time to test and install different lighting mods; very informative in the least. Some I absolutely love, and some I don't.That's what makes it nice when someone takes the time to experiment and do it, so we can all see.
But the damn weather won't let me enjoy sunshine everyday.I have a few more already purchased mods, but i think I am done spending money.
Plus, i will have to remove all **** if i sell the car.
Yes, it works with all 3 color modes. (The seller will ask if your car has ambient and the number of colors). I think it's just bright enough not over saturate the front cabin. I will be doing the fronts memorial day weekend.
Here is an edited preview of the front mid with all the other front lights.
(its running on a 9 volt battery in the picture, so it may be a little brighter on 12 volts)
Here are all 3 colors. (Mercedes Benz white is actually light pink. orange + white)
I was thinking of just putting the mids in the backseat because i was worried about it being too bright and saturated while driving, maybe a bit tacky but after seeing your pics im leading towards the whole package. I usually keep my lights on the solar color so i was wondering if you would be able to take a picture of the whole setup with the solar color? the picture you have of the mid with solar looks a bit off to me. Thanks a lot for your great posts, keep up the good work
