Post your panoramic roof problems and fixes!
Old Apr 2, 2024 | 05:57 PM
  #126
nasroo7's Avatar
2017 Mercedes C300 Sport 4Matic AMG Pack (W205)
Thank you!
Old Apr 5, 2024 | 01:28 PM
  #127
nasroo7's Avatar
I've downloaded all these documents already.
For the "remove_install headliner.pdf" in step 4 we get to "Remove inside rearview mirror (A67)", which is linked to a document "Remove/install inside rearview mirror", which takes to a link to mbwis net which doesn't exist anymore.
There are many other links within the pdf documents for in-between steps.
Old Apr 5, 2024 | 01:31 PM
  #128
Cls55beast's Avatar
2006 Cls55 amg
Type in panoramic repair Mercedes on YouTube.
There’s multiple videos that show you exactly what to do. Pretty straight forward after seeing those. Good luck.
Also, Flyboyusa sells a replacement clips kit that usually fix the issue.
Old Apr 5, 2024 | 02:09 PM
  #129
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
This is what I have.
Old Apr 9, 2024 | 03:09 PM
  #130
nasroo7's Avatar
Downloaded these, and completed these steps. Thank you!
I'm however stuck with the headliner.
I'm trying to remove it, and I removed the interior mirror, the pillars, the roof garb handles, sunvisors and the overhead console.
Now, the headliner is stuck by the sunroof, and I can't figure out what's blocking it.
Anyone ran into this? Or knows what's the next step here?
Old Apr 9, 2024 | 03:39 PM
  #131
nasroo7's Avatar
I made it! I just had to pull around the sunroof a little harder.
Old Apr 10, 2024 | 09:21 AM
  #132
luxuries's Avatar
Benz
WOW ! I am impressed, it seems to be such a big job ! Congrats and thank you to keep us updated !
Old Apr 10, 2024 | 02:47 PM
  #133
nasroo7's Avatar
documents
Do you have the documents about the removal of the panoramic sunroof rails?
Old Apr 10, 2024 | 04:01 PM
  #134
nasroo7's Avatar
I
I got both rails unhooked at the back, and I'm going to tilt them and see if I can remove the interior pieces of the rail and find what's broken. Because from the outside, I can't find what's blocking the mechanism.
Old Apr 18, 2024 | 08:11 PM
  #135
nasroo7's Avatar
Anyone has the instructions on how to remove the rails from the front?
Old Apr 28, 2024 | 12:40 PM
  #136
nasroo7's Avatar
Not finding any more information online, I downloaded the WIS software.
it was helpful in figuring out some steps needed.
I was able to take apart the sunroof rail and found the bad piece.
I'm ordering a replacement piece, and will see what happens.
I also need to find which lubricant I should use.
Hopefully, it'll fix it.
Old May 5, 2024 | 10:07 PM
  #137
nasroo7's Avatar
Found this piece on the guide rail that was broken. This is what caused the panoramic sunroof to fail.
I'm unable to find a replacement online.
Anyone has an idea?
Old May 8, 2024 | 04:37 PM
  #138
nasroo7's Avatar
Anyone has an idea?
I purchased this kit. it seemed to have these pieces.
i'll try it this week end.
Old May 8, 2024 | 09:43 PM
  #139
cidtek's Avatar
C300 4Matic Tenorite Grey
Please let us know how the install went.
Old May 28, 2024 | 10:35 PM
  #140
nasroo7's Avatar
I ended up needing the two white plastic pieces.
I installed them in the guide rails, and I also replaced the sunroof slider, both purchased from Amazon.
Note that the guide rail sliders were not perfect, and had to manually trim some of the plastic that was overflowing from the plastic mold, and used my drill to make the rear holes on it as the same size as the original sliders, because the holes on my purchased sliders were slightly smaller, due to plastic that was overflowing. The metal measurements were good.
Applied a generous amount of lubricant.
I made a video of the guide rail sliding from open to close position, but the website didn't let me upload the video. The mechanism will first pull the front part of the arms holding the glass, then will pull the rear Arm holding the back. You must have both stages working pretty much.
Once everything mounted, I found out that the Motor wasn't pulling on the guide rails all the way. It was pulling the front part of the glass to close position, but the rear stayed lifted open. In other words, the first stage was complete, but the second stage didn't start.
The difference this time, is that I was able to manually close and open the mechanism all the way (The mechanism was stuck before, due to the broken parts).
Using the WIS Software, I found out that the Motor pulling on the sunroof only has 2 screws holding it.
There are two motors, the one by the passenger side is the one controling the sunroof.
I unscrewed both screws and removed the Motor.
I manually adjusted the metal spring wire that pulls on the sunroof, and placed the Motor, and activated the sunroof a few times. Kept removing the motor and adjusting the metal spring wires, and activating the motor, until I got the adjustment I needed after half a dozen tries.
It's either that, or you take it to the dealer to adjust the motor using the STAR software for $250.
After that, it was all good.
Note that anytime I was activating the sunroof mechanism, I had the 8x screws (4x on each side) that are holding both guide rails slightly loosened. My reasoning is that I didn't want any pressure on the Glass, which could cause it to shatter.
After getting the adjustment I needed for the Glass, and everything, I tightened all the screws holding the guide rails. The screws are located under the roof, and are accessible only after you remove the overhead roof fabric.
I had another issue, while I was happy with the positioning of the guide rails, I tightened the 8x screws holding them (4x on each side), but I applied too much torque with my impact driver. Which caused one to snap, and slightly bent some others.
So, I went to the nearest Mercedes dealer, and purchased: A 176 782 00 60 64 ($40 a bag of 5x screws). I bought 2x packs and replaced all my 8x screws.
This part is found on the w205 coupe model's parts list, but is also the same as the sedan (Every website said that it wasn't compatible with the sedan. That's why I bought them from Mercedes, for about the same price once you count the shipping fees of the websites).
I replaced all of them.
Before mounting the overhead components, I took the car on a test drive to check for wind noises.
I made a couple of adjustments on the Glass height with the front screws, until I was happy with the wind noise.
After that, I mounted everything back.
While mounting the sunvisors, one of the metal clips slipped from my wrench tool, and jumped inside the roof. I used a small telescopic magnet that I had in my tool box, which grabed it, and I gently brought it to the hole. I had a little sweat for that one. Then, installed it.
I drove the car, the panoramic sunroof is now fully functional.
So, all in, it cost me $180 in parts.
$60 Guide rail sliders.
$20 Pack of plastic pieces.
$80 Guide rail screws.
$20 Lubricant
As far as labor, since I don't have a garage, but was using a family member's garage, I couldn't work on the car anytime I had free time. I worked on it on some week-ends. If I had the garage where I live, I would've finished it in a couple of weeks, because I was ordering parts, as I took it apart and found the issues.
If I had all the parts handy, I could do it all in a week-end.
Also, since it was the first time, I had to discover that mechanism and how to get to it.
Now, I know.
I also replaced the Auxiliary battery, since it started giving me the error a few months ago.
I bought the OEM battery for $60.
There is a very good video on youtube made by FCP EURO. I followed it.
Next step, is to vinyl wrap that glass cover on top of the windshield, because even if you replace it, it'll just fade again after a couple of years.
In any case, I'm very happy with the result and glad I avoided spending the $6,500 the dealer quoted me for the sunroof, and the $1,200 for the Auxiliary battery.
Old Jun 2, 2024 | 03:05 AM
  #141
jiceoo's Avatar
2018 GLS550 & 2015 S550 gone but not forgotten: 2001 S500, 2006 ML500, 2010 S550 & 2014 GL550
After going through all 6 pages, I still cant find the solution to my issue. Only the driver side will tilt up, passenger side wont raise up at all. Other than that the roof will not open all, I even tried to manually open the roof and it doesn't work either. Can someone please assist on how I can get the glass to open so that I can remove it and repair the issue. I have the headliner down and removed the screws that hold the rails, but still cant remove the glass from the car due to the metal rods that are coming from the motors.
Old Aug 14, 2024 | 04:29 AM
  #142
nikinikica66's Avatar
MB GLE 350de
Hello!
I have to replace sunroof Roller Blind on my GLE Coupe V167. How to do it in the easiest way ?
Part for replacement: https://mercteil.com/mercedes-benz-a...are-part-54zVE
Old Sep 20, 2024 | 02:20 AM
  #143
Dean.'s Avatar
Where do the white plastic buts go?
[/QUOTE]
I have had my roof apart a couple of times, i have replaced the side part of the rails as well as the front hinges and still does not work. The roof attempts to lift and then just closes again. To put into vent mode, you hear the motor move but nothing happens.
where do these white plastic bits go as I never come across these when I originally looked at the roof.
thanks.
Old Sep 20, 2024 | 01:26 PM
  #144
benzdude's Avatar
Top Answer: 1
Might as well install roof starlight while that liner is already off.
Old Sep 27, 2024 | 12:02 AM
  #145
JohnTopete's Avatar
Dropped off my car at an auto glass shop in socal
Sunroof was stuck closed with an annoying wind noise at 35+ mph. It would attempt to open but only passenger side would actually move but only a tiny bit before motor would click, driver side wouldn’t even budge. Bought the car on 9/11 that way so I’m not sure how or when it happened. The sun shade was also jammed open, couldn’t even pry it open with force. While sunroof was jammed.
Dropped it off at an auto glass shop on 9/16, said they’ve done these before.
It’s been almost two weeks 0_o
$1350 - “complete sunroof assembly”
Going to pick it up this weekend finally. If all is good I’ll shoot you guys the shop name if you want it.
Old Nov 25, 2024 | 06:17 PM
  #146
nasroo7's Avatar
So, what happened?
Originally Posted by JohnTopete
Sunroof was stuck
Old Nov 25, 2024 | 06:18 PM
  #147
nasroo7's Avatar
These pieces go at the front part of the rails.
The rail has a square hole for this piece.
thanks.[/QUOTE]
Old Nov 25, 2024 | 06:20 PM
  #148
nasroo7's Avatar
I seriously considered it, but felt that the moonroof took over too much space to allow for a meaningful amount of stars. So, canceled the idea.
Old Nov 25, 2024 | 06:38 PM
  #149
JohnTopete's Avatar
So, what happened?
Cost me $1,400 and almost a month without the car. They did get the sunroof to open/close, they couldn’t get the wind deflector to function though.
If I could go back, I would’ve took my time and done it myself or just coughed up the money for dealership to handle.
Be weary of any “shop” willing to do this sunroof job on our cars. The shop I chose ended up being a huge mistake on my part. I think about those *******s anytime I open my sunroof and enjoy my hair dancing in the wind. The damage they did to my roof liner and A pillars also reminds me of my poor decision making… good luck out there
Old Nov 30, 2024 | 02:57 PM
  #150
axelwphoto's Avatar
2016 C63 Sedan (W205)
Lightbulb Drop-in solution for excessive wind noise on MOST Pano-Roofs
Looking at all the threads & forums, I've designed and produced a drop in fix for similar issues that people are describing. Dropping this for help!
Let me know how it works and how I could improve it!
Works great so far in my test-vehicle; my personal w205 C63!
Cheers everyone!
https://ttartcollection.com/collecti...cls-class-c257
- Axel / Axel W Photo / Ttart Collection
