Post your panoramic roof problems and fixes!
The shades open and close correctly. When I try to open the roof to position one (tilt) only the back left side starts to lift, (the back right seems jammed and won’t lift up). Whilst it is trying to open, there is a grinding noise from the motor/gears. I then press the close button and it closes again correctly. I’ve scanned for faults in the closed and half open positions with no faults detected.
I’ve been quoted £2000 by two local garages for parts and labour to replace the various parts when the roof hasn’t even been stripped to verify the issue (apparently the whole roof has to be stripped and the front seats taken out to inspect.
Please post your problems and fixes here to help me and others who experience it, thanks!
Without even looking, yes, that price seems high you need to take it to someone that is familiar with the sunroof.
Both parcel shelf guide motors have thrown out their spring type things, the bonnet latches have failed three times and it’s developed a weird acceleration issue, when it feels like it is doing a dpf regen where the throttle response goes, until it hits 2000rpm then takes off like a scalded cat and slams the next gear in like a learner...
feels like I have a Friday afternoon car
Which of the repairs aren't covered by the extended warranty resulting in you being responsible for $3,200?
W205's - to help prevent prevent the problem the sunroof system "should" be lubricated with spray PTFE at each 1Yr/10K service - and lubricated if the "auxiliary battery (capacitor) gets replaced and needs to be to restore memory/stop setting on the sunroof - but the Mercedes maintenance schedule only calls for "check sunroof" - and when auxiliary capacitor is replaced does not call for sunroof or window resetting
Many people have had aux battery malfunction and the capacitor assy replaced I wonder how this also correlates with the many pano roof failures?
I can hear it when my music is off on rough roads. It drives me nuts. *turns up bass*
I might attempt to remove the glass this summer (since it looks fairly easy)
have you tried asking MB to goodwill repair it? There's an LI about it and everything.
The PCV issue is just a cold weather thing I wouldn't even mess with it
Since the repair was made at a dealer, using OEM parts, I now have a 2-year warranty on the sunroof at any dealer in the country.
