W205 PCV?
Old Jun 8, 2019 | 11:31 AM
tdao75's Avatar
c300 2015
W205 PCV?
I have a 2015 C300 W205. I got a check engine light with codes P052E, P052E-71. The scanner says "The valve fro crankcase has a malfunction. The actuator is blocked". I called MB dealer PCV part but they said that W205 engine doesn't have a PCV. Does anyone know that w205 has a pcv? If yes where is its location? Thanks in advance for your help.
Old Jun 11, 2019 | 01:36 PM
JChristjr5's Avatar
2015 C300 4matic
Same thing
Had the same issue happen no more than 3-4 weeks ago. It’s in the lower engine assembly... if you are trying to do it yourself... don’t. Take it in. Cost of repairs were $1300 before my service warranty. It was a full day repair. About 8 hours on the lift
Old Jun 11, 2019 | 08:22 PM
Elbandito's Avatar
2015 c300
Seems like a lot of people are running into the same issue. I had it repaired under extended warranty
Old Jun 11, 2019 | 09:44 PM
tdao75's Avatar
c300 2015
Thanks JChristjr5. Your info is very helpful. I already booked an appointment with MB dealer to check up since I still have 2 months of warranty. Hopefully they will cover it? I google the part number that you give me. I think it is the one in the picture (mark in red) but I am not 100% sure.
Old Jun 11, 2019 | 10:46 PM
JChristjr5's Avatar
2015 C300 4matic
it is a warranty covered part.. nothing you could have done.
Old Jun 12, 2019 | 04:26 AM
W205_Merc's Avatar
2002 E55 AMG, 2015 Mercedes C300 4Matic
had mine replaced at 40K miles...
its a pricey job that involves removal of a bunch of items to replace it... thus time consuming... :/
Old Jun 12, 2019 | 08:02 AM
JChristjr5's Avatar
2015 C300 4matic
Mine was replaced at 38k.
Old Jun 12, 2019 | 11:32 AM
GringoBling's Avatar
C400
They will cover it
also emissions related parts (which this is) have a longer warranty
Old Jun 12, 2019 | 02:17 PM
Flytim3's Avatar
2015 c300 w205, 2013 Nissan 370z
Originally Posted by GringoBling
They will cover it
Are you certain this is covered under emissions warranty because mine came on last winter then miraculously went away by itself. Mines 2015 so the warranty may run out soon. I rather have MB replace it sooner rather than later.
Old Jun 12, 2019 | 06:16 PM
C400
its in the warranty booklet
Old Jun 12, 2019 | 07:33 PM
Flytim3's Avatar
Thanks. Time to bust it out and read. 😊
Old Jun 12, 2019 | 08:21 PM
DoorHandle_LED's Avatar
2015 C 300 4MATIC
My post from a few months ago has everything you need: https://mbworld.org/forums/c-class-w...ode-p052e.html
I finally had my repair done last Friday. Took my indie mechanic 4 hours to complete the job. Parts cost me around $350 from my local MB dealer.
Old Jun 24, 2019 | 03:32 PM
tdao75's Avatar
c300 2015
I finally got it fixed by dealer and it was covered by the warranty. Thank you for your comments. They also fixed 2 door handle LEDs which were burnt out a year ago under the warranty.
Old Jun 24, 2019 | 04:15 PM
JChristjr5's Avatar
2015 C300 4matic
Glad it worked out for you!!
Old Jun 24, 2019 | 04:23 PM
Flytim3's Avatar
Originally Posted by tdao75
I finally got it fixed byy dealer and it was covered by the warranty. Thank you for your comments. They also fixed 2 door handle LEDs which were burnt out a year ago under the warranty.
That's definitely gives me a bit of hope as my vehicle is the same year. Hoping warranty doesn't run out before it happens. Fingers cross.
Old Apr 6, 2023 | 05:58 AM
Alex.j's Avatar
2015 MB C300 W205
Hi, friends, I have got the same (P052E - crankcase vent valve malfunction) for my 2015 MB C300 W205 BASE, RWD (NOT 4 MATIC) a few days ago. So I spent about 20 hours to find for parts to fix the malfunction but I have had no success. Could u be so kind of writing all necessary part nos. I should get be replaced please?
