Crankshaft sensor position 1.
Old Jul 22, 2019 | 02:07 PM
Jmarlvis's Avatar
C300 2015 formatic
Does anyone know where the crankshaft sensor for C300 2015 located?
Old Jul 22, 2019 | 02:12 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
010 POSITION SENSOR
CRANKSHAFT001 A 27 090 500 43
Old Jul 22, 2019 | 02:27 PM
Jmarlvis's Avatar
C300 2015 formatic
Thanks for your reply, does the above diagram for w205 engine?
Old Jul 22, 2019 | 02:28 PM
Agent-A01's Avatar
Yes
Old Jul 22, 2019 | 02:34 PM
Jmarlvis's Avatar
C300 2015 formatic
Originally Posted by Agent-A01
Yes
Do you have a clear picture of it?
Old Jul 22, 2019 | 03:57 PM
thunderfoot's Avatar
C300/GL450
This is what it the part looks like.
Old Apr 9, 2021 | 06:15 PM
marcosv's Avatar
96 E320
Yes I think I can see the wire going to that direction but how do I have access to have it removed and replaced?
Old Apr 9, 2021 | 10:00 PM
kevinmelone's Avatar
2015 C300 4-MATIC Sedan
So with the car raised in the air and the under covers removed, the sensor will be hidden in a very small crevice to the left of the catalytic converter’s heat shield.
You’ll have to remove two heat shields (to the left of the catalytic heat-shield I mentioned before) to be able to find it.
The sensor itself is held in by 2 E-Torx screws, and is in a horrible position to reach.
What helped me was to remove the air box and both heat shields from under the hood before you raise the car up.
Personally my hands are way too large to feel around inside that crevice for the sensor clip and bolts, so I would recommend using a mirror to find where everything’s located at.
Technically you should only need a thin 1/4” flex ratchet with a stubby extension and a swivel E-Torx socket (do not quote me but I believe it was an E8 male torx socket).
Sorry I don’t have any pictures to show you, but hope this helps.
Old Apr 10, 2021 | 03:45 PM
marcosv's Avatar
96 E320
Thank you Kevin,
My C300 the air box is on the right side and I removed but my arm does not reach the sensor. Apparently mine is in the back under the ECU. Thank you once again.
Old Jul 18, 2025 | 03:53 PM
Aezzat94's Avatar
2016 C300 w205
What does removing the air box do here?
