Fastest W205 C300
Old Jul 29, 2019 | 06:36 PM
Bcureton's Avatar
2015 C300 W205
Fastest W205 C300
Hey everyone,
I have a 2015 Mercedes C300 that’s in the shop right now because of a blown engine and turbo. I’m having the same 2.0L I4 engine put back in, but pure turbos are building me custom turbo internals that are stage 2. After the engine, turbo, and a new Weistec downpipe are put in the car is going to get tuned. I should have about just shy of 400 crank horsepower. I am very curious if anyone has beaten this number with a W205 C300. If so I’d love to hear about your setup.
Old Jul 30, 2019 | 11:08 AM
C300AWD's Avatar
C300 4matic
I haven’t heard of anyone really tuning past 300 hp with turbokits turbo. Following... would love to see that much power from your car!
Old Jul 30, 2019 | 11:38 AM
JAMADOR's Avatar
2015 C300 Sport
They [MB/AMG] coaxed 416hp out of the M139 (granted with numerous changes), so anything's possible with enough $$
Looking forward to your results.
Old Jul 30, 2019 | 01:54 PM
MercedesN8's Avatar
15' C300 4Matic
How did your engine get blown? Just curious as I'm a new 15' C300 owner don't want that to happen to me.
Old Jul 30, 2019 | 02:25 PM
Bcureton's Avatar
2015 C300 W205
Thanks for all the support guys,
I actually had an oil leak while running the car at a rpm and speed it probably shouldn’t have been at at the time, because I was misfiring out of cylinder 1. But basically the car ran itself out of oil and caused the motor and turbo to seize. I haven’t exactly got a straight answer yet out of what caused it but I was told it was caused internally and not by aftermarket parts that I had on at the time
Old Jul 30, 2019 | 05:03 PM
Terminator1's Avatar
W205 C250
My opinion is that there is no way to safely hit 400hp (not even less than 300hp) without upgrading engine internals like rods and pistons. You can check SKN tuner from Switzerland, they did managed to push it to 400hp. but with serious engine upgrades.
Old Nov 26, 2023 | 07:16 AM
dabuch83's Avatar
2015 C300
Its possible
Originally Posted by Bcureton
Hey everyone,
Sorry I know im late to the party here.
So I am at just 400hp with no internals changed except valve springs and let me tell you I have so many issues with my gearbox. Here is my setup
1. tornado tuning intercooler
2. tornado tuning Charge pipe
3. tornado tuning catless down pipe
4. tornado tuning turbo intake pipe
5. carbon fiber intake pipes
6. tornado tuning cold air intake
7. Turbo kits.com 59mm turbo with coated manifold
8. AMR stage 3 tune
9. AMR transmission tune
10. brand new 722.9 transmission
11. Tornado tuning high performance coil packs
12. turbo kits.com valve springs.
13. GFB BOV (because recirculating 32psi can cause turbo lifespan issues)
make sure you have a good tune on that transmission because the 722.9 from the c43 does not play nice so the factory transmission is the only option.
Old Nov 26, 2023 | 08:37 PM
dagger22's Avatar
2019 CLS450 (C257)
8. AMR stage 3 tune
Have you dynoed your car and have the chart to share?
Old Nov 27, 2023 | 04:53 AM
dabuch83's Avatar
2015 C300
I live in the middle of nowhere and the closest 4wheel dyno is about 3 hours away but to answer your question directly no. I plan on going into town after Christmas and getting it dynoed.
Old Nov 27, 2023 | 09:43 PM
dagger22's Avatar
2019 CLS450 (C257)
Cool, keep us updated!
Just trying to set realistic expectations..... its definitely not easy to hit 400hp (and also depending on whether its on wheel or on the crank)... even with the Turbokits hybrid turbo.
you would need something larger like a Borg Warner EFR 6758 with meth and a lot of boost to get there... OR... if you are using Ethanol fuel to bump up the power.
So far with those who have extensively modded their rides, there is a substantially higher torque which they will feel, but it doesnt constitute the higher hp since the torque is more low to mid rpm and dropping off thereafter at the higher rpms.
Cheers!
Old Nov 28, 2023 | 05:15 AM
dabuch83's Avatar
2015 C300
Cheers!
I appreciate that I dont want to look like an *** telling someone where I think my car is at lol... here is why my mechanic thinks im at least close to it.. he took all the conservative lows in his figures
Stock HP 241
1. intake: +10 = 251hp
2. catless downpipe + 15hp = 266hp
3. Turbo kit turbo + 80 hp = 346hp
4. stage 3 amr tune +30hp = 376hp
5. downpipes back exhaust + 10hp =386hp
so he figures we are sitting at 386hp at the crank are these figures unrealistic and why? Obviously the dyno will answer that but on my 335xi when I lived closer to town we dynoed after each mod and made a bit higher for each one of the mods above. like 15hp for intake and 25hp for the catless pipe, 50hp for the tune and so on... thank you for setting me straight either way.
Old Nov 30, 2023 | 01:21 PM
MaverickC43's Avatar
Amg C43
What kind of numbers can u get driving?
0-60
20-100
1/4 mile
people don’t talk hp as much, imo
bc it’s all bout being fast 👍🏼👍🏼
