JB4 tuning
The 2019 in the UK has a OBD check so I get a notification that Mercedes Me is malfunctioning when infact its fine so bear that in mind.
Performance wise I'm relatively happy, clearly much faster than standard >3000 rpm. Running Map2 but the custom tuning support was a little limited, they basically just said leave it on Map2 and you'll be fine. Some people who have dyno'd the 2019 seem to have less power than pre facelift and I'm not sure why but the full reflash people also have the same issues.
Also bear in mind, if you buy the Bluetooth adapter it doesn't include the app that you have to pay more for which is a little annoying.
I know that the fourth plug is needed only with some special gaz that I’m not going to use, but shouldn’t 3 plugs be connected or is two okay?
Would that be the same with a JB4? Meaning there’s no way that two plugs connected could be the way to go right? I wanna show them this when I go back to install it next week.
Hopefully it didn’t mess up anything having only two connected...
