Passenger side ambient light
Old Sep 11, 2019 | 02:16 PM
TorbenK's Avatar
C220D W205 Estate
It is plug and play to the factory ambient light.
Old Sep 11, 2019 | 02:19 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Can't wait to see your pictures. Good job.
Old Sep 11, 2019 | 03:17 PM
TorbenK's Avatar
C220D W205 Estate
Old Sep 11, 2019 | 03:42 PM
benzdude's Avatar
Top Answer: 1
Well damn it. I had my GLC door wiring harness (2535409609 $25) ready to convert my DIY one to 3 color ambient.
Old Sep 11, 2019 | 03:48 PM
benzdude's Avatar
Top Answer: 1
BTW that's not plug and play. You will need to do some soldering.
Pro Tip you can test the leds before installing using a 9 volt battery, brown wire should be ground (-). blue = blue light (+), orange = orange light (+) I assume.
Old Sep 11, 2019 | 04:08 PM
Doa's Avatar
Doa
W205
Ordered mine today. $175
I still assume I will not need to cut or solder something to my existing cable tree... since it say plug & play
Old Sep 11, 2019 | 04:22 PM
  #32
benzdude's Avatar
Top Answer: 1
$175????? I thought it was $137?
Chinese DIY skill level is high, so "plug and play" could mean soldering required.
Also, If you look at Torbenks photos, that black wiring harness connector doesn't fit any MB plug near the center console. Good Luck
Old Sep 12, 2019 | 12:04 PM
  #33
benzdude's Avatar
Top Answer: 1
Any tips on how to remove the trim? Does the screen need to be removed?
Old Sep 12, 2019 | 12:23 PM
  #34
TorbenK's Avatar
C220D W205 Estate
The seller tells me that it plugs between the plugs of the OEM ambient light, so you should not solder anything. Hence plug and play. Of course you need to remove some screws and so on, but come on...
And actually I think the plug will fit in my retrofitted ambilight.
Old Sep 12, 2019 | 12:31 PM
  #35
TorbenK's Avatar
C220D W205 Estate
Which seller? Kerdie Liang from Facebook?
Or link above?
Plugs should fit in your existing ambilight plugs.
Old Sep 12, 2019 | 12:49 PM
  #36
benzdude's Avatar
Top Answer: 1
I've done ambient 3d tweeters, ambient mid speakers and all ambient vents on my car and the sellers always say "should fit standard Mercedes plug", but they never do. Maybe i didn't look in the right places?
Also, the soldering was not a big deal because i only had 3 wires to figure out.
Old Sep 12, 2019 | 12:53 PM
  #37
TorbenK's Avatar
C220D W205 Estate
Hmm.. I did ambient light in doors and center console. No problem. No wire cutting.
Old Sep 12, 2019 | 01:01 PM
  #38
benzdude's Avatar
Top Answer: 1
Does it work with the factory 3 color ambient system? Do the leds have 3 wires or two?
Actually, my 3d tweeters were plug and play. They came with a small black control box attached, which plug into the door controller.
The rest all came with those tiny black connectors. I have a nice collection of them.
I must've made a mistake.
Old Sep 12, 2019 | 01:04 PM
  #39
TorbenK's Avatar
C220D W205 Estate
Why would you cut these plugs when the harness is plug and play?
The plugs from the passenger side ambient light will fit the plugs you show in the photo!
Old Sep 12, 2019 | 01:05 PM
  #40
benzdude's Avatar
Top Answer: 1
@TorbenK Thanks again for your detailed photos. It has given me an idea.
Old Sep 12, 2019 | 01:08 PM
  #41
benzdude's Avatar
Top Answer: 1
Yes, as I said, all the Chinese ambient kits I received came with those black connectors, but I never found were they would plug in, so I cut them off and made my own connection to the Mercedes wires.
Let me know if you find where they go and I will kick myself.
Old Sep 12, 2019 | 01:18 PM
  #42
TorbenK's Avatar
C220D W205 Estate
Here. Go kick yourself.
Clearly you did not read the instructions
https://mbworld.org/forums/attachmen...tion-guide.pdf
Old Sep 12, 2019 | 01:43 PM
  #43
benzdude's Avatar
Top Answer: 1
Cool
OMG! Please don't tell me you did that whole PDF. Oh Man, that's a lot of work.
BTW, That kit is for a car with no factory ambient package from Mercedes. My car already has factory ambient leds in the console, along the doors, in the ash tray, foot-wells, roof light, etc
Also, You can clearly see that you need to insert the big blue plug into the door controller #6 port (that's where my 3d ambient tweeter is tapped) and the console lights get power from inserting those pins into an already existing Mercedes door harness.
So NO KICKING Needed.
The good news is if you've already done this complicated install on your car then YES, you will have a 3 pin Chinese black connector in your console to tap into.
Otherwise, no original Mercedes factory ambient connector will work.
Old Sep 12, 2019 | 02:08 PM
  #44
TorbenK's Avatar
C220D W205 Estate
Ow, I thought you had retrofitted the ambient light
Old Sep 12, 2019 | 02:10 PM
  #45
benzdude's Avatar
Top Answer: 1
Dude how long did all of that take?? A week?
Old Sep 12, 2019 | 02:44 PM
  #46
TorbenK's Avatar
C220D W205 Estate
I did not do it all in one step, but I spent a few nights. It was great fun
Old Sep 15, 2019 | 03:46 PM
  #47
benzdude's Avatar
Top Answer: 1
My DIY version is installed. Works with factory ambient. $40
Old Sep 15, 2019 | 07:41 PM
  #48
shan16's Avatar
C250
Can you please link all the item used to DIY I have 64 color ambient light
Old Sep 15, 2019 | 08:38 PM
  #49
benzdude's Avatar
Top Answer: 1
Sorry, No idea. I only have 3 color.
Old Sep 17, 2019 | 11:48 AM
  #50
Doa's Avatar
Doa
W205
Got mine today... product is ok but its without connector so no plug and play at all...
Its not rocket science but on this car I wanted to keep all electricity oem and now ill have to cut my cable tree and add an other connector as I also need to be able to disconnect this thing if needed in the future
