S205 analog clock retrofit
Hi everyone,
I want to change my centre consolle from the awful (to me) piano black to the nice (to me) black ash wood. And I was looking to have the analog clock which is not installed on my car.
I talked with my dealer and he said it was possible. But now he said that he does not know where it has to be connected. I had confirmation from the part supplier and therefore I have ordered all the necessary parts. Now I have all parts to made the replacement, but I have no idea on how to connect the analog clock.
I have tried to look for a post with a discussion on how to connect the analog clock, in the forum but I did not find any. And that strange because I remember that when I have seen something about that on this forum
Is there anyone who can help me to identify from where to where I have to pull a cable or give me the part number of the cable used on models with the analog clock from factory?
Thanks in advance
Thanks in advance
C220D W205 Estate
I've done it.
It was not that hard.
It need signal from COC 26
To retro-fit an analogue clock in a W205 C class, you need a 12VDC supply (red wire+) a ground (brown wire -) and a yellow wire (LIN to auto update the time) this must be connected to the front SAM module (plug COC pin 26) which is situated above the footwell (top left or right corner depending on LHD or RHD) You will have to remove the cover over the hood release handle. The SAM unit is above the cover but the access to it is not great and is sometimes difficult to find for the first time! (It is a Grey unit about 20cm x 15cm with 5 plugs connected to it. If you do not make this connection with a yellow wire to pin 26 - the clock will not set to the correct time automatically.
Good Luck.
Good Luck.
I've done it.
Good Luck.
Good Luck.
I have purchased exactly the same black ash wood console with the clock. I am looking forward to find the time to install it. But I started to be worried about the clock when I asked where to connect the cable to my local Mercedes dealer and they told me that it was no possible...
May I ask you some additional questions on that connection?
I will check during next weekend where the SAM module is on my car. I have a RHD as your one.
Since I do not know yet so much this car (I have it only since 2 months) may I ask you where did you connect the 12V+ and -? I assume the + should be connected to a always on 12V, not switched off by ignition contact. Moreover, on the clock, I see there are 3 plugs but there is no indication of what they are for, they are just named 1,2 and 3. Maybe do you remember which one is for what?
I have the original connector on clock side. Is there a special connector for the SAM module?
I will do the job myself, I have some experience on electric circuit on cars.
My last question is for something else. Is your screen the original one? it looks larger than mine (which is a pre-restyling) and definitely with a different graphic.
Thanks again!
C220D W205 Estate
Hi.
Hehe, not possible? A lot have done it.
You are right about the connections. Actually I had a repairshop to make the wiring. I was at a service check anyway, so they did it for a very small Price.
You can pick up a permanently live +12v. supply from any convenient point (i.e. establish that the supply is constant even with the Ign. in the 'off' position, but be sure to insert a 3amp. inline fuse into the circuit for safety protection) pick up a - neg. from any convenient close by point available [lighter socket?]
You need the plug that goes into the clock. I bought this at Mercedes and had them plug the wires into it.
They should know which colour goes where.
A0375456328 plug part number.
About your other question....
The screen is something I've retrofitted.
Its is a 10.25 android tablet developed for Mercedes (and other brands).
If you are interrested, there is a (still evolving) usergroup here: Android 10.25 Mercedes user experience' group
BTW: Found this for the plug...:
Hi.
Hi. thanks again for your info.
I have already that connector, same code, but without wires...
Today I have spoken again with my Mercedes dealer. After my questions they have given me the electrical schemes of the car (limited to the clock) and I have found all 3 connections. The clock signal is the number 26 as you have mentioned, but I have found also the + and -. I need to identify them on the car now, but I am pretty confident that the work is easy. I will probably check that next week, as soon as I have some time.
I will post the result once the job will be done.
Hi, I come back on this post because I still have not managed to connect the watch… With the electrical scheme received by Mercedes, I have identified the 3 necessary connections on the scheme.
The one to synchronize the time is in the gray box near the hood releaser. I have the pin number but… I cannot see where the pin is physically located. And I do not have the metal pin for the connection.
Concerning the "+" connection, I cannot find where the one shown on the scheme is. I cannot find it in the car. Also in this case, I suppose there is a metal pin, which I do not have.
The "-" is less problematic because can be connected everywhere, but in theory it should be connected to the "common ground" point which I cannot identify in the car.
Last but not least, I have the plastic connector for the clock side, the one shown in the pictures above, but I have realized that I do not have the internal metal pins…
Because the scheduled maintenance service was approaching, I stopped my research and I asked support to my Mercedes dealer. I have explained them in details what is my problem with this watch and they told me there were going to look at that.
Last week I had the service. They told me that they were not sure about the connections and they have not done anything. They asked support to Mercedes Benz in Germany and they have to call me back, but honestly I have some doubts that they will come back with a solution.
Therefore, I am here for asking some support from somebody of you who has personally done this connection.
Thanks is advance.
Thanks is advance.
Hi.
1. I have located the front Sam unit at the footwell. How do I disconnect the blue connector? There seems to be a grey lock on the blue connector. How do I take it out to pull out the blue connector? And how do connect the yellow wire to the pin 26? Just push it in?
2. On the driver side, this are all the fuses that are available in my car. Which is the correct 12V to connect the red wire to?
At the fuse for the analog clock. There isn’t a wire that connects it at the back even.
thank you in advance!
The following 4 users liked this post by SilverBullet18:
Hi, I fitted black wood consoles with clock to my w205. The clock always stops 6 hours after the car is turned off. After opening the door, it spins and positions itself properly. It is like that every day. What could be causing this? Please help
Analogue clock fitting
Hi.
HI
Where do I find the wires seen above. I only have the connecter purchased from MB
Hi bro this is Daren from Malaysia , I have the same problem too I have follow all the step upper but the clock still not working , my question is ; is it gonna code 1st to make the clock move ?
