digital cluster retrofit
#101
Fromt censor in my digital dashboard
Hi, my front censor parking shows like this im my digital Dashboard (in the center top) -aftenmarket installed on my 2015 C220d - absolutely love it! It look better Then the originals in my eyes. 🤩
#102
Hey, just installed mine from the same vendor. I really like it, but my blinker sound is very loud. Did you have the same problem?
#104
Any other issues I should know about? I find the brightness at night too bright even at it’s lowest settings of 10%. I may try tind a matte window film to put over to see if that helps.
#105
Hmm mine is not that bright at 10%, seems ok for me, but everyone is different so.but we Can write Them to fix this in next Update to the cluster. Maybe so you Can go 9,8,7,6,5,4,3,2 and 1 % as Well. Only other thing … They misspelled startup - it says “stratup” 🤣
The following 2 users liked this post by Doa:
Darrick30 (08-14-2023),
merc8desbenz (08-14-2023)
#108
Ya Well, i have asked their support to swap the font with one that looks more like the original font. Also asked for the speedo digits to go in the middle for the “Vanguard” display option… we will have to wait and see… you should all do the same, the more customers that ask, the more likely They are to change it faster. 👍🏼
#110
#112
[QUOTE=jonsailo;8818016]Yes you are correct, I have the parking sensor indicators on the roof at the back - I'm more referring to the front sensors, which don't show up anymore. Wanted to see if anyone has done a digital dash conversion and where they see their front indicators. Attached here is the view of both dashboard and the centre screen.
As you can see for front sensors, I can only rely on the bottom right car icon of the camera view (when in proximity, there will be a yellow/red bar surround the car telling you there is an object nearby) - this is only turned on when I put the car in reverse.
But when I am moving forward and manoeuvring in tight spaces, I won't see this graphic...can only hear the beeping sound when I get too close to an object. I originally thought the bar above the digital speed are the parking sensors, but they don't appear to have any function...
do you have maps working? just did this and my maps is not working who did you get to code your system
#113
I Think You have the original digital cluster from the face lift model? Mine is the Android one. Your font does not look the same as mine. My Android cluster is plug and Play.
