Same size Tires on Staggered Rims?
Old Oct 28, 2019 | 01:54 PM
Timlim's Avatar
2015 c300
Hello,
I have a 2015 c300 with the sport package (staggered tires set up)
My question is if it's possible for me to put the same size tires on the front AND the rear.
My understanding is that the rear rims are wider when compared to the front.
I'm wondering if i can put 225 width tires on the front and rear.
Thanks.
Old Oct 28, 2019 | 02:18 PM
alexasa's Avatar
c
sure - but it will look dumb as hell
Old Oct 30, 2019 | 07:04 AM
RemmyZero's Avatar
2016 C300 4matic
Are you asking if you can put 225 tires on the stock staggered rims? or asking if you can just put 225 rims & tires on the front and back?
You can absolutely put 225 rims & tires on the front and back. That's what I do for my snow setup and you cannot see a difference. The stock staggered rims are wider but they do not stick out past the front rims so no one would know if you went with the 225.
Old Oct 30, 2019 | 08:46 AM
Coffee_break's Avatar
2019 C300
From the topic subtitle the OP seems to be asking if he can put 225 mm tires on staggered rims (7.5" front and 8.5" rear). Technically the answer is yes according to website https://www.tyres-pneus-online.co.uk...ce-advice.html
Rim width Minimum tyre width Ideal tyre width Maximum tyre width
7,5 Inches 205 mm 215 or 225 mm 235 mm
8,5 Inches 225 mm 235 or 245 mm 255 mm
A 225 mm tire is the absolute minimum that a 8.5" rim can handle. I would be concerned that that tire is stretched too much and has no sidewall to protect the rim against curbing.
Old Oct 30, 2019 | 08:53 AM
RemmyZero's Avatar
2016 C300 4matic
Also, I don't know about stretching run-flats like that. I'm not sure how it affects the effectiveness of the internal support structure in the sidewall.
Old Oct 30, 2019 | 09:20 AM
2019 C300
True. That’s definitely a concern. That’s why I bought separate rims for winter at 8” all around. That was the TireRack recommendation for 225 mm run flat winters on a 2020 C300 4Matic.
Separate set of rims makes changeover easier by not having to mount and dismount tires every season. Tire bead and rims can be damaged plus no rebalancing.
@RemmyZero is your winter set up on square rims?
Old Oct 30, 2019 | 09:44 AM
Timlim's Avatar
2015 c300
I see, it may be too much to stretch the run flats like that.
Do you know if its possible to run 17 inch rims all across for c300's with the sport package?
I've been reading a lot of conflicting info on whether or not the rims would clear the breaks.
Old Oct 30, 2019 | 10:00 AM
2019 C300
I think it depends on the specific 17” rim whether it’ll clear the larger brake calipers.
Chat with TireRack people if going after market for rims. Maybe dealer could try one on if you’re going with MB rims.
Old Oct 30, 2019 | 11:24 AM
RemmyZero's Avatar
2016 C300 4matic
Is there a specific reason why you want to go with 17s? The price difference in most of the tire/wheel packages I looked at on tire rack was around $150-200 between the 17" and 18", so the price difference isn't that extreme. My understanding was that not many 17" rims would clear our calipers. Plus if this is for snow then i'd take every last bit of ground clearance you can get. Luckily I can raise mine up with the airmatic but it's not by much.
Old Oct 30, 2019 | 11:35 AM
Timlim's Avatar
2015 c300
I have a set of 17 inch rims from a previous w204 that I had.
Just wondering if I can slap some thicker tires on those instead of buying a whole new set.
Old Oct 30, 2019 | 11:41 AM
2019 C300
Perfect....just try them on.
Ground clearance should be unaffected going from 18” to 17” if you keep the overall diameter the same (this will also prevent any speedometer offset).
