There are two manual shifting modes. Temporary and Permanent. Temporary mode is engaged by pulling one of the shift paddles, but as stated above after a certain amount of inactivity it automatically reverts back to automatic shifting. Permanent mode on non AMG models can only be engaged via the Individual mode as stated above. Set up the Individual mode with the transmission setting in manual mode and then activate the Individual mode and the transmission should stay in manual shifting mode until you change to another drive mode or turn off the car. AMG models have a manual transmission mode button on the center console and the function can also be put on one of the programmable steering wheel buttons of the AMG Drive Unit, so manual shifting mode can be permanently engaged from any mode. Also for non AMG models, even if you are in manual shifting mode, the transmission will automatically upshift as you reach higher rpms closer to redline. AMG models on the other hand have a true manual mode and they won't upshift and instead let you run into the rev limiter like a car with a traditional manual transmission.
