Noticeable hood/bumper gap
Old Feb 7, 2020 | 02:06 PM
Bmarcinczyk14's Avatar
2016 C300 w/ sport package
Does anyone else have a noticeable gap between the hood and front bumper? It measures at 5.8mm, I'm wondering what other W205's measure at. The hood looks to be aligned properly so moving it forward more might make it misaligned in other places, so maybe it's something with the front bumper. Either way I'd let to have it fixed to what's considered an "acceptable" amount of gap.
Old Feb 7, 2020 | 02:11 PM
GringoBling's Avatar
C400
yeah mine is cuz it hooked and dragged on a curb.
it's adjustable
Old Feb 7, 2020 | 02:41 PM
it's adjustable
The front bumper is?
diamondsilver16's Avatar
2016 C300W4 (W205), Luxury Pkg, Diamond Silver Met. and Silk Beige\Espresso Interior
As mentioned it is adjustable, however that gap looks pretty typical for the model.
Old Feb 7, 2020 | 04:26 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Normal
Old Feb 7, 2020 | 04:44 PM
Originally Posted by GreekUPS
Normal
I haven't had a chance to inspect another one in person yet but from pictures of cars on autotrader many seem to have less gap. I'd be curious what others measure at for gap.
Old Feb 7, 2020 | 06:48 PM
nick_wass's Avatar
C300 Sport W205
You can adjust the top and reduce the gap to minimum. There are 3 screws- see pictures.
Old Feb 7, 2020 | 06:58 PM
I'll check it out when I get a chance, are these pictures from a c300? Is it just a matter of loosening the screws and pushing the bumper in then tighten? Is it hard to get both sides even? I may just have my dealer do it so I dont screw things up more and hopefully it's simple enough they won't charge me
Old Feb 7, 2020 | 07:04 PM
nick_wass's Avatar
C300 Sport W205
Yes C300. It is easy - loose and adjust. Just don't leave pressure or over tighten.
Old Feb 8, 2020 | 01:08 AM
fabbrisd1's Avatar
A gaggle of MB's
Interesting thread - (1) your Gap Is normal (2) the Narrow gap is NOT NORMAL - and the NARROW GAP is way wrong and to anyone in a collision center would "seem" to indicate a front end accident and bad front grill replacement.
I guess no one here so far understands the reason why the Normal gap is there....
Old Feb 8, 2020 | 02:01 AM
k4vglitcher's Avatar
2017 AMG E43
The gap is totally normal. Honestly, looks better with it. That narrow gap from that white c300 looks bad to me, doesn't give it that decline affect, if that makes any sense. Just like it was mentioned by previous users, you can easily adjust to tighten if it bothers you with the top three screws.
Old Feb 8, 2020 | 02:50 PM
It would also make logical sense to use the panel gaps around the rest of the car as your guide. You want all of the gaps around the entire car to be fairly uniform.
Old Feb 8, 2020 | 02:54 PM
nick_wass's Avatar
C300 Sport W205
I also think the gaps should be the same all around the hood, and nterested to learn why a 5mm “normal gap” is needed.
Old Feb 8, 2020 | 03:11 PM
Trappers101's Avatar
2016 C300 4matic
Once you "fix" that gap I'm sure you'll find others. Are you sure you want to go down this road?
Old Feb 8, 2020 | 04:24 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Old Feb 8, 2020 | 04:25 PM
benzdude's Avatar
Top Answer: 1
When you slam the hood down (with that tight gap) bad things might happen.
The Mercedes recommended panel GAP measurements are attached.
File Type: pdf
Old Feb 8, 2020 | 04:51 PM
The factory minimum spec is 2.5mm which is pretty darn tight.
Old Feb 8, 2020 | 04:59 PM
benzdude's Avatar
Top Answer: 1
I believe it's 3.5mm for ( location C ) Engine hood to radiator trim/soft nose on a w205.0/1. (± 1 mm)
Old Feb 8, 2020 | 05:07 PM
3.5 +/- 1 which means 2.5mm is considered acceptable
Old Feb 8, 2020 | 05:40 PM
I just measured my fender-hood gap and it is exactly 1/8 inch (~3mm). My grill-hood gap was about 4.5mm, but I have had my grill on and off multiple times.
I adjusted my grill down to a 3mm gap and the uniformity looks good to me.
Thanks to this thread for giving me something to do on my Saturday afternoon
Old Feb 9, 2020 | 04:33 PM
So I adjusted it down to around 4mm. Now I'm noticing a little more gap on the left side where the hood curves when stepping back and looking at it for some reason. I tried messing with the other adjustment further down on the left side of the bumper but didn't seem to help. Not sure if I want to live with it or deal with having the dealer or body shop tinker with it and maybe I'll think it's worse than before lol.
Old Sep 28, 2024 | 09:40 PM
WriterandPhotog's Avatar
2022 MB C 300 Coupe
This is an interesting discussion: on my 2022 C 300 coupe, the front bumper cover had been damaged, so I replaced it. All screws, top and bottom, lined up and were reattached. The problem is that the bumper cover on the right (passenger) side isn't high enough to properly line up with the hood/bonnet. Drives me nuts because I like everything to align. My back tail lights on the quarter panels and trunk didn't line up, and I replaced the pull-down motor (or actually, reattached it) and everything lined up perfectly. I had seen one picture in a forum of a torx screw behind the grill that could be loosened to adjust the front bumper cover, but it didn't work with mine. Does anyone know of an adjustment to raise the height of the bumper cover on just the passenger side? I even adjusted the bumper on the hood/bonnet so the hood would sit lower, but it's still not right. I can't handle panels that are misaligned.
Old Nov 1, 2024 | 09:52 PM
2022 MB C 300 Coupe
Anyone have any thoughts or insights on this
Old Nov 2, 2024 | 03:02 PM
W205C43PFL's Avatar
Does this thread further help? https://mbworld.org/forums/c450-c43-...ender-gap.html
Old Nov 2, 2024 | 09:57 PM
2022 MB C 300 Coupe
Thanks for posting the link. Yes, the hood bumper was the first thing I had tried, (adjusted all the way down to the lowest setting) but the hood isn't really the problem, it is the height of the bumper cover. I had found another discussion about that topic, but the adjustment available on the car photographed in the discussion was different than mine. I am sure Mercedes must have some form of adjustment for the vertical movement of the front bumper cover, but I have not been able to locate it and my dealer doesn't have a body shop, and they just referred me to who they deal with, so that I can pay hundreds more to learn where a screw resides.
