My review/installation of Audiotec Fischer Match speakers and amplifier - pic heavy
Old May 23, 2020 | 10:03 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Originally Posted by BayAreaAMG
BTW just FYI for anyone reading the thread, I forgot to mention that after a long time messing around with the EQ my final tune setup was 90% based on a file created for BMW sedans using the UP 7BMW amplifier. My original tune was in a lot of ways similar to this one except that this one was more refined. I was often still using the radio settings to adjust treble and mids, but with this tune I can keep those at 0 and the overall sound quality is even better than what I originally created. If anyone has the same amp and wants to check out the tune please PM me for the tune file I am using. I tried uploading it to this reply but it's apparently an unsupported file type.
Please post a link to the tune file or pm it to me. I can load it in the helix DSP software in demo mode. I would actually like to see what distance settings you have set.
Old May 23, 2020 | 10:21 PM
BayAreaAMG's Avatar
2016 C450 AMG
You just jogged my memory that I can use Google drive to share it via a link. I never use it, but now I have a reason to. Try this link and let me know if for some reason it isn't working right
https://drive.google.com/folderview?...hdqcdJlwyFlW9f
EDIT: I just referenced my screenshots and I don't have any distance added to any of the channels. I could add some appropriate amount and test it out, now I want to go back to my car and play with it.
Old May 23, 2020 | 10:24 PM
benzdude's Avatar
Top Answer: 1
Thanks. I will check it out.
Old May 23, 2020 | 10:31 PM
BayAreaAMG's Avatar
2016 C450 AMG
Originally Posted by irondad
Excellent write up and pictures that provide useful information. I'm very happy with my Burmester but I'm sure this will be very useful for anyone thinking about an upgrade.
If I had the Burmester I probably wouldn't upgrade anything in the system since it sounds great already. I had a 2019 C300 loaner car with it for a few days and thought it sounded pretty good. But who knows, I may have ended up modifying it at some point .
Old May 23, 2020 | 10:33 PM
BayAreaAMG's Avatar
2016 C450 AMG
You're welcome, try starting out with a distance of 2.58 ms front speakers, and 4.63 ms rear. That's what the BMW tune file for sedans had. It had none for center or subs.
@benzdude I went out to the car and added the distance, since I forgot to do that initially. It sounds so much nicer now thanks for bringing it up.
Old May 23, 2020 | 11:00 PM
benzdude's Avatar
Top Answer: 1
This all started to fix the crappy footwell sub bass.
​​​​​I also tried a 2020 c class and it still sound bad to me.
The V Twelve dsp has a new feature which allows you to sum or passthrough the factory tune (one to one channel routing) on the channels you want and tweak just the ones you need.
​​​So i could keep the Burmester tune on all speakers and tweak the footwell subs to sound better.
Old May 23, 2020 | 11:14 PM
  #32
benzdude's Avatar
Top Answer: 1
Good info.
https://www.audiotec-fischer.de/en/d...ning-magazine/
Old May 23, 2020 | 11:33 PM
  #33
benzdude's Avatar
Top Answer: 1
Actually, I plan on using distance mode (time alignment) and measure the distance of all the speakers from the drivers seat. Input that into the Software and let it set the required delays.
This is how the Audison DSP software does it.
My Audison distance settings with Match speakers:
LF = 30.1 (inches)
RF = 30.1
FLW = 20.1
FRW = 30.1
RL = 13.4
RF = 32.3
Trunk Sub = 66.9
Looks like you are using the delay mode option in that second tune file.
Old May 23, 2020 | 11:39 PM
  #34
BayAreaAMG's Avatar
2016 C450 AMG
Yep I switched it to delay mode to input the delay in time as the BMW file does. I'm going to further experiment with it some more and measure it out, testing it in centimeters. The Match software seems to have the option of either centimeters, inches or milliseconds.
Old May 24, 2020 | 12:01 AM
  #35
benzdude's Avatar
Top Answer: 1
If you are going to use distance mode you might want to flatten all EQ settings first (all channels). Then input the measurements for each speaker. After that play a few songs (with flat eq) and solo the speakers in groups while you adjust the distance settings to your liking. So only front left and right, then rear left and right, then front and rears, woofers, etc. Mute the other channels.
After you've got the distance and delays where you want then tweak the EQs.
Some people prefer the vocals coming from over the steering wheel or over the center speaker location. Tweaking the L/R time alignment will allow you to choose.
Old Jul 13, 2020 | 06:18 PM
  #36
benzdude's Avatar
Top Answer: 1
The DSP PC-Tool software has been upgraded. New features. V4.70a.
https://www.audiotec-fischer.de/en/d...ool-version-4/
Now includes Automatic Time Alignment measurement!
ATM - The official public beta version of "Automatic Time Measurement" has been added. This is a completely new algorithm and function which allows the user to fully automatically set up the time alignment in a car for all speaker channels independent if these are active or passive speaker systems. The new function can be accessed by pressing "SHIFT" + "t" in any window. To use the function name ALL inputs and outputs correctly, make sure that a full range stereo signal is routed to analog input channels "A & B" or in case of VCP to Virtual Channels "Front Left" and "Front Right" and play the ATM test track from the Sound Files folder. The microphone needs to be mounted in a fixed position at the the centered head position e.g. mounting the mic to the headrest facing upwards or in a 45° angle to the inner roof. At last make sure that the measurement volume is in the green/good marked area of the microphone level bar and click on the "Start" button. If necessary it is possible to select/unselect specific channels in the table of the new window.
Old Jul 13, 2020 | 06:27 PM
  #37
BayAreaAMG's Avatar
2016 C450 AMG
Nice, I will have to give this a try. I want to look for a decent mic to try this on first. Thanks for the update on that!
Old Jul 13, 2020 | 06:43 PM
  #38
benzdude's Avatar
Top Answer: 1
Just got my V TWELVE DSP after over one month waiting.
Ebay shipper (Pitney Blows) lost it, then found, then crushed it. What a nightmare. Hopefully it still works.
Old Jul 13, 2020 | 06:47 PM
  #39
benzdude's Avatar
Top Answer: 1
All the cool kids say these mics are very good.
Amazon Amazon
Amazon Amazon
*Expensive
Amazon Amazon
Old Jul 22, 2020 | 03:13 PM
  #40
W205guys's Avatar
2016 C300 4MATIC
I’m looking into doing the same type of setup, but I would really prefer to not use a passive crossover, I would rather the tweeters get their own channels in the DSP. I can’t tell if the UP 7DSP with this harness would be able to accomplish this. Any ideas?
Old Jul 23, 2020 | 12:15 AM
  #41
BayAreaAMG's Avatar
2016 C450 AMG
The harness or amplifier doesn't have any additional outputs/channels that you could use for that. I can't think of any way to make that work with this setup, except maybe if you sacrificed the rear doors from having their connection to the amp you could use them for the tweeters on their own left and right channels.
But idk to be honest if that's worth the effort and results. You'd have amplified speakers except in the rear, the volume levels will sound louder up front so you may have to play with the fader. But also in comparison to the rest of the speakers, the quality won't be great at all.
Well, if it were me I wouldn't attempt it. I don't think it's worth the effort when it all sounds great and the way it is with how I have it installed.
Old Aug 2, 2020 | 07:50 PM
  #42
yianni_g's Avatar
2019 C300 4MATIC
Thank you for all the pointers! Found the A20 system underwhelming and wanted some more power. Going with a plug-and-play system was my preference. The contenders were between the Match/Eton systems. I chose Match due to local inventory and the amount of online resources.
The Match system was professionally installed in my vehicle. There's a huge difference in comparison to the stock A20 system. The sound is punchier and distortions are no longer heard at high-frequencies. The sub-woofers produce amazing bass.
Only slight drawback is, the sub-woofers are too loud on low volume settings. This could be to the way it was setup. Adjusting the in-car equalizer bass option did not help much. I'm not expert, but believe this could be an easy fix and adjustable through the DSP as a setting. It might make sense to add a remote control to fine-tune sub-woofer volume on the go.
Old Aug 2, 2020 | 08:24 PM
  #43
BayAreaAMG's Avatar
2016 C450 AMG
It sounds like it has the dynamic bass enhancement enabled, which will increase bass to the sub at lower volume levels, and taper it as it gets louder. You can disable it in the sub fx menu. Adding a remote helps a bunch to control it too.
Old Aug 26, 2020 | 02:02 PM
  #44
Nithikorn8's Avatar
C238 e300 coupe
hi sir,
how was the new v twelve dsp, I am planning to upgrade the burmester to the v twelve dsp. Could you please give a review on this dsp.
thank you
Old Aug 26, 2020 | 02:21 PM
  #45
benzdude's Avatar
Top Answer: 1
Originally Posted by Nithikorn8
hi sir,
thank you
https://www.bestcaraudio.com/product...dsp-amplifier/
https://www.audiotec-fischer.de/en/b...blogArticle/52
Old Aug 26, 2020 | 02:26 PM
  #46
benzdude's Avatar
Top Answer: 1
I found this typo very funny. That's a lot of woofers.
Old Aug 26, 2020 | 02:54 PM
  #47
botaggs1's Avatar
2016 E350 4Matic Sport
Just completed my set up today and really happy with the results. Have each of the door speakers replaced with Eton Crossovers on each one. Then I have a JL monoblock amp and 8 inch microsub in the back. However, I'm getting the itch to install a 4 channel JL amp to send 60 watts to each speaker just to see how big of an improvement it would be (already vastly improved as is).
Old Aug 26, 2020 | 03:26 PM
  #48
BayAreaAMG's Avatar
2016 C450 AMG
Lmao 20 woofers! That's a good one.
Old Aug 26, 2020 | 03:42 PM
  #49
benzdude's Avatar
Top Answer: 1
40 as it reads.
Old Aug 27, 2020 | 10:42 PM
  #50
benzdude's Avatar
Top Answer: 1
If you have a Burmester amp in the trunk and want to completely delete it from your chain, you can use the NAV-TV ZEN-M MOST 150 interface and retain all factory features.
Audiotec Fischer has now made a well written manual for the ZEN-M and their DSP AMPS.
*Attached
