Constant 12V in rear fuse box
Old May 31, 2020 | 09:34 AM
be749309's Avatar
C300e Hybrid
Hi,
For a C300e hybrid S205 model I need some help.
for a dashcam installation I need a constant 12V and a Acc switched 12V supply in the rear trunk fuse box.
I have the Acc switched 12V. No issue here.
But for the constant 12V it seems that after ending the charging cycle or after a certain time with the car off and locked even that constant 12V cuts off.
Who can help me locating a constant 12V source in the rear fuse box ?
Or where can I find it.
I do not like to wire directly from the cars battery.
Thanks for any assistance !!
Old May 31, 2020 | 11:15 AM
stockbmw's Avatar
2018 C43
If you have both driver's and passenger footwell fuseboxes, constant battery is there on regular non-hybrid w205.
On driver's fusebox there are both constant and accessory fuses.
Old Oct 5, 2021 | 01:13 PM
Stalinik's Avatar
Mercedes-Benz GLC 2020
Hi, I’m having the same issue on my GLC 2020, did you find a way to have a permanent 12V fuse?
For now I’m connected in the rear/ trunk fuse box with 66min. parking time.
The car is full with these “false” permanent fuses.
Old Oct 5, 2021 | 01:28 PM
PaulR7's Avatar
W205
https://fotohostingtv.ru/show.php/18...20720.jpg.html
412, 459 and 460 should all be permanent live.
Old Oct 5, 2021 | 02:05 PM
Stalinik's Avatar
Thank you! I will try them out and get back.
Fingers crossed!
Old Oct 8, 2021 | 05:17 AM
Stalinik's Avatar
I tried fuse 412 and unfortunately the same problem (live for aprox. 60 min.)
Next I will try fuses 459 and 460.
Old Oct 8, 2021 | 01:25 PM
PaulR7's Avatar
W205
Did you check the health of your battery? These cars are a bit clever and I suspect the post facelift version might even be more clever and will shut off almost everything if the voltage of the main battery gets too low.
Old Oct 8, 2021 | 01:34 PM
Stalinik's Avatar
The health of the battery could not be the issue here. It did crossed my mind that this new models from MB might have something clever installed. 😅 I hope it’s not the case. This weekend I will try several fuses that seem to have permanent voltage. Also I will try the fuse for the analog clock, and ultimately I will try to connect directly to the battery.
Old Oct 8, 2021 | 01:43 PM
Stalinik's Avatar
I find it interesting that I didn’t find anybody on forums or internet with this particular issues. Isn't anyone interested in hardwire-ing dash cams on new Mercedes cars?
Old Oct 8, 2021 | 01:50 PM
PaulR7's Avatar
W205
I've got a dashcam hardwired in my 2014 W205 but that's going to the driver's side fuse box, I managed to find both constant and switched live in there, can't for the life of me remember which ones they were but could probably open it up later on tonight and have a looksie.
Old Oct 8, 2021 | 01:57 PM
Stalinik's Avatar
In the fuse box diagram on the driver’s side I found the analog clock fuse. This should be always on as the multimeter shows (like the other fuses that I have tested and proved they are not). I will test the fuse this weekend.
Old Jul 25, 2023 | 10:56 AM
mr. mister's Avatar
W205
sorry wrong thread
Old Aug 24, 2023 | 12:43 PM
WVM's Avatar
WVM
C43 AMG
Help
Did someone find out where to connect a dashboard camera ? I need permanent 12V for parking surveillance ! 🙏
i have a 2017 W205
Old Oct 4, 2023 | 08:04 PM
mbstealership's Avatar
2014 c300 4matic luxury
i have a 2017 W205
did u find out? I also bought a dash cam and found out I do not have the inner driver side fuse box.
