PLEASE HELP c300 Rotational Grind Noise front end
Old Jul 13, 2020 | 05:55 PM
Yqr's Avatar
Yqr
2015 c300 4matic
Anyone know what this is? Brakes and everyrhingbhave been checked by MB dealership. They said it was tire bead flexing on rim so the dismounted, sealed and remounted tire. The noise remains.
https://youtu.be/yM9QUYDBIc0
Old Jul 14, 2020 | 01:51 AM
Mikesmith2939's Avatar
C200 estate 2019 AMG line premium plus.
Could be a stone stuck between the back plate and disc on one of the wheels.
Old Jul 14, 2020 | 12:22 PM
RemmyZero's Avatar
2016 C300 4matic
I have the same exact issue with mine. 2016 with ~74,000 miles now. My plan is to replace my brake rotors this weekend or next so i'll take it apart and let you know what I find. My personal guess is that it's my rotor since i've never replaced them for the life of the car, but I won't be sure until I get everything apart. I've replaced the pads once at around 25-30,000 miles with ceramic pads but I don't believe they are the issue. It very well could be a stone or foreign object trapped in there but my thoughts are that it would have popped out by now because i've had this for a while and since it started i've also swapped my summer/winter rims once and didn't see anything obvious.
Old Jul 18, 2020 | 11:25 AM
RemmyZero's Avatar
2016 C300 4matic
So I took the wheel and caliper off and took a good look at everything. I have a slight lip on the front of the rotor, but nothing unexpected. What I did see was two things that tell me it's time to replace the rotor...
1. The back of the rotor has somewhat excessive circular etching, which is not visible on the front
2. The rear pad in the caliper has the normal circular wear marks but there are jagged etchings about 90 degrees to the pad and you can put your fingernail in there so it has some depth.
My pads are ceramic, replaced around 20k miles and the rotors are original (77k miles now). The pads are barely worn but i'm confident i've outlived the life of the rotors. I'll order some this week and replace them next weekend and report back.
Old Jul 19, 2020 | 07:59 PM
Yqr's Avatar
Yqr
2015 c300 4matic
I dont kno but i took it back to the dealership, they said they put extra lube on the tire and the noise is gone. I honestly dont know with this car anymore. Wierd little crap that $179 you you to death
Old Jul 20, 2020 | 07:34 AM
Trevor Hadley's Avatar
mercedes w123 260e
Show us a picture .....
Old Jul 20, 2020 | 11:53 AM
Yqr's Avatar
Yqr
2015 c300 4matic
Of what?
Old Jul 21, 2020 | 01:14 PM
blizzard12's Avatar
2017 Mercedes-Benz C300, 2017 Mercedes-Benz GLC300
It sounds like a broken belt in the tire. Could also be runflat low on pressure:
Old Jul 28, 2020 | 12:54 PM
Yqr's Avatar
Yqr
2015 c300 4matic
https://youtu.be/2C1jUzummrQ
mone sounds really similar to that. And worse when I'm turning around in a u-turn or cul-de-sac.
Old Jul 28, 2020 | 12:58 PM
Yqr's Avatar
Yqr
2015 c300 4matic
I drove away from the dealership and the noise wasnt noticable, by the time I got home it was grinding the same way.
Old Aug 6, 2020 | 05:06 PM
RemmyZero's Avatar
2016 C300 4matic
I replaced both my front rotors last weekend and the issue is gone. I can't say for certain your problem is the exact same issue but for me it was night and day difference. I have to get my front drivers side tire replaced next week. I'll see if they notice anything when they do it.
