Extra long crank than runs perfect, 2013 c250 1.8t
Have a p0002 code for fuel pressure. Seems like the the pressure regulator isnt holding pressure after shutdown
This means a new hp fuel pump, or if something else to look for? The HPFP has a regulator built in
I feel like maybe they released this software though to cover up the fuel pump failures and make them last a little longer but it's worth looking at.
If let run long enough, spiking the RPM to get the fuel pump turning faster, after 20 minutes the car would run and start great. 20 mins every time. Like there was air in the high pressure system that bled out. Takes awhile.
It continues to start and run great for an hour or so afterward. Next day it's exactly the same. Low pressure and takes 8 seconds to start.
Replaced the fuel pump, it's a little better but still the same problem.
Seems like its losing pressure somewhere. Maybe through leaking injectors?
Is there a return line on the high pressure system or possibly leak back through the pump?
~50psi when starting cold and after startup
~1000 psi when running after it
~200 psi after shutdown and keeps dropping slowly afterward
Engine has good power after 30 minutes of driving. Everytime. And low pressure fuel is always there quick. Longer the engine stays off the worse it runs. Feels like rail gets air in it.
After bumping Rpm up and down a bit, I see pressure fluctuate up to 300 but drops back down when let off gas.
Keeps improving then after running for 30 minutes pressure stays around 1000+ and power is solid
After shutoff, restart is quick and power still there.
So really seems like fuel is leaking out or back somewhere. No exterior fuel smells.
