Lots of error codes, WTF!
Old Feb 7, 2021 | 11:02 AM
Kim Nyholm's Avatar
W205 C220 4Matic Diesel
Unhappy Lots of error codes, WTF!
I started the car yesterday and the engine fault light came on. Car runs normaly, only problem has been that I´m not able to check Adblue level. It has been really cold outside (-5 to -18 degrees) lately and the car battery has been in poor condition.
I took the car to a warm warehouse and charged the battery, but still the fault code list huge and have try to clear them but no success.
Would there be any ideas where the fault is?
============1==============
U0101(FA)
Raw code: C101FA
ECU: 7EA[Archive (inactive)]
Status: Pending, Confirmed
OBDII: Data bus, transmission control module (TCM) - no communication
Mercedes-Benz: Lost Communication with TCM
============2==============
U0101(FF)
Raw code: C101FF
============3==============
U105C(FC)
Raw code: D05CFC
============4==============
U045A(E3)
Raw code: C45AE3
OBDII: Invalid data received from parking aid control module A
============5==============
U1444(E1)
Raw code: D444E1
============6==============
U0100(FA)
Raw code: C100FA
OBDII: Data bus, engine control module (ECM) A - no communication
Mercedes-Benz: Lost Communication with ECM/PCM A
============7==============
U0100(FD)
Raw code: C100FD
============8==============
U045A(E2)
Raw code: C45AE2
============9==============
C053B(FE)
Raw code: 453BFE
============10==============
U105C(FB)
Raw code: D05CFB
============11==============
U105C(FA)
Raw code: D05CFA
============12==============
U045A(FF)
Raw code: C45AFF
============13==============
U045A(FB)
Raw code: C45AFB
============14==============
U045A(E0)
Raw code: C45AE0
============15==============
U045A(FD)
Raw code: C45AFD
============16==============
U045A(FC)
Raw code: C45AFC
============17==============
U045A(E5)
Raw code: C45AE5
============18==============
U0420(E1)
Raw code: C420E1
OBDII: Invalid data received - power steering control module
============19==============
U0420(E0)
Raw code: C420E0
============20==============
U0420(FF)
Raw code: C420FF
============21==============
P068B(00)
Raw code: 068B00
ECU: 7ED[Archive (inactive)]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
OBDII: Engine control (EC) relay - shut-off delay
============22==============
U0164(87)
Raw code: C16487
Status: Confirmed, Test failed since last DTC clear
OBDII: Data bus, AC control module - no communication
============23==============
P008A(00)
Raw code: 008A00
ECU: 7EB[Archive (inactive)]
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Low pressure fuel system - pressure too low
============24==============
P0627(00)
Raw code: 062700
Status: Test failed since last DTC clear
OBDII: Fuel pump (FP) control - open circuit
============25==============
U0155(31)
Raw code: C15531
ECU: Transmission control unit[Archive (inactive)]
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
OBDII: Data bus, instrumentation control module - no communication
============26==============
P0606(00)
Raw code: 060600
OBDII: Engine control module (ECM)/powertrain control module (PCM) - processor fault
Mercedes-Benz: PCM Processor Fault
============27==============
U0126(00)
Raw code: C12600
OBDII: Data bus, steering position sensor control module - no communication
============28==============
U0146(00)
Raw code: C14600
OBDII: Data bus, gateway A - no communication
============29==============
U0121(00)
Raw code: C12100
Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear
OBDII: Data bus, anti-lock brake system (ABS) control module - no communication
============30==============
U0100(00)
Raw code: C10000
Status: Pending, Test failed since last DTC clear
============31==============
U0141(00)
Raw code: C14100
OBDII: Data bus, body control module (BCM) A - no communication
============32==============
P042F(71)
Raw code: 042F71
ECU: Engine control unit[Archive (inactive)]
OBDII: Exhaust gas recirculation (EGR) valve actuator A - actuator stuck closed
============33==============
P2463(09)
Raw code: 246309
OBDII: Diesel particulate filter (DPF) - DPF restricted
============34==============
P0336(64)
Raw code: 033664
OBDII: Crankshaft position (CKP) sensor - range/performance problem
============35==============
P13E7(FD)
Raw code: 13E7FD
============36==============
P220F(77)
Raw code: 220F77
============37==============
P220E(77)
Raw code: 220E77
============38==============
P229F(91)
Raw code: 229F91
Status: Test failed, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Nitrogen oxides (NOx) sensor 2, bank 1 - circuit range/performance
============39==============
P204F(96)
Raw code: 204F96
OBDII: Reductant system, bank 1 - performance problem
============40==============
P13DF(09)
Raw code: 13DF09
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============41==============
P1403(00)
Raw code: 140300
OBDII: DPFE Sensor Hoses Reversed
============42==============
P20B9
Raw code: 20B9
ECU: 7EC
Status: Pending
OBDII: Reductant heater control A - open circuit
============43==============
P20BA
Raw code: 20BA
ECU: 7EC
Status: Pending
OBDII: Reductant heater control A - circuit performance problem
============44==============
P13DF
Raw code: 13DF
Status: Pending
============45==============
P20B9
Raw code: 20B9
ECU: 7EC
Status: Confirmed
============46==============
P13DF
Raw code: 13DF
Status: Confirmed
Old Feb 8, 2021 | 02:43 AM
Mikesmith2939's Avatar
C200 estate 2019 AMG line premium plus.
You can't delete them because they are not active only pending.
Old Feb 9, 2021 | 07:31 PM
dagger22's Avatar
2019 CLS450 (C257)
Which OBD tool are you using to clear the codes? and did you clear the codes while the engine is running?
Old Mar 5, 2021 | 07:04 PM
Lord Stanley's Avatar
CLK350
This happened to me after messing with fuses inside the cabin. I missed a fuse putting them all back. Car ran, but lit up like a christmas tree. The fan was running high too. When I got out of the car, the problem was on the ground, a single fuse I missed somehow. Put it back in, and all was well. Guessing you have the same fuse out, that I failed to put in. Hoping it is that simple anyway.
Old Jul 23, 2024 | 06:03 PM
Kareemjunaid's Avatar
E class 2013 - W 212
What was your fix?? I had the same issue recently it's been really stressful.
U0101(FA)
Raw code: C101FA
U0101(FF)
Raw code: C101FF
U105C(FC)
Raw code: D05CFC
U045A(E3)
Raw code: C45AE3
U1444(E1)
Raw code: D444E1
U0100(FA)
Raw code: C100FA
U0100(FD)
Raw code: C100FD
U045A(E2)
Raw code: C45AE2
C053B(FE)
Raw code: 453BFE
U105C(FB)
Raw code: D05CFB
U105C(FA)
Raw code: D05CFA
U045A(FF)
Raw code: C45AFF
U045A(FB)
Raw code: C45AFB
U045A(E0)
Raw code: C45AE0
U045A(FD)
Raw code: C45AFD
U045A(FC)
Raw code: C45AFC
U045A(E5)
Raw code: C45AE5
U0420(E1)
Raw code: C420E1
U0420(E0)
Raw code: C420E0
U0420(FF)
Raw code: C420FF
P068B(00)
Raw code: 068B00
U0164(87)
Raw code: C16487
P008A(00)
Raw code: 008A00
P0627(00)
Raw code: 062700
U0155(31)
Raw code: C15531
P0606(00)
Raw code: 060600
U0126(00)
Raw code: C12600
U0146(00)
Raw code: C14600
U0121(00)
Raw code: C12100
U0100(00)
Raw code: C10000
U0141(00)
Raw code: C14100
P042F(71)
Raw code: 042F71
P2463(09)
Raw code: 246309
P0336(64)
Raw code: 033664
P13E7(FD)
Raw code: 13E7FD
P220F(77)
Raw code: 220F77
P220E(77)
Raw code: 220E77
P229F(91)
Raw code: 229F91
P204F(96)
Raw code: 204F96
P13DF(09)
Raw code: 13DF09
P1403(00)
Raw code: 140300
P20B9
Raw code: 20B9
ECU: 7EC
Status: Pending
P20BA
Raw code: 20BA
ECU: 7EC
Status: Pending
P13DF
Raw code: 13DF
Status: Pending
P20B9
Raw code: 20B9
ECU: 7EC
Status: Confirmed
P13DF
Raw code: 13DF
Status: Confirmed
Old Jul 24, 2024 | 08:42 AM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
Clear all the codes and rescan after you have driven the vehicle. Based on the errors, it looks like there is an issue with one or more of the CAN networks. Possibly a module, a corroded connector, or a break in the wiring.
Old Jul 26, 2024 | 10:34 AM
Cosworth2000's Avatar
2022 E53 AMG
You can't remove archived messages if you don't have the right scan tool. You can read codes in most and remove service related codes but you can't remove archived codes. These codes are stored for future reference in the modules however if the car is running normally, you can ignore the codes.
