Wheel fitment
Old Apr 26, 2021 | 06:00 AM
MRCPN0810's Avatar
S205 2015
Wheel fitment
Hi guys,
I just wanted to ask if someone has the same wheel/tire fitment and how is it on a w205 estate/sedan 2015 (stock hight, non amg)
does it rub anywhere or is it a good fit for the car?
8,5jx19 5x112 ET45
235/35/19 91Y
Old Apr 26, 2021 | 10:40 AM
Keith66's Avatar
2018 AMG E43
I have a similar setup (19x8.5 ET45), but I'm lowered 3+ inches on coilovers. On mine, the inner fronts were very close to the upper steering knuckle, so I went with a 5mm spacer to an effective ET of 40. I never drove it at ET45, so I'm not sure if it would have rubbed or not. There are two factors that contributed to my setup being closer to the steering knuckle than yours may be; 1) I'm lowered. 2) I went with 245/35/19 tires because I wanted the little bit of extra width and I prefer my sidewalls to be somewhat square with the wheel. I'm not a fan of the stretched look... just my personal preference.
I think in your case (stock suspension) you'll be good with what you listed, just pay attention to the front-inner clearances with a 8.5 wide wheel at ET45 and go with a thin spacer if needed to push the wheel out a bit.
Even being lowered, no rubbing issues here, except for a very light rub in the rear when entering/exiting parking lot entry dips at a diagonal angle.
(BTW, mines a 4Matic if it makes a difference)
Old Apr 26, 2021 | 12:00 PM
MRCPN0810's Avatar
S205 2015
Thanks, I will be lowering it in the future and I will probably use some spacers too to get that flushed look so its good to know that this fitment works
Old Apr 26, 2021 | 03:33 PM
Keith66's Avatar
2018 AMG E43
You're welcome and good luck! I've found on mine at least, the "goldilocks zone" for offset on a 8.5 wide wheel with 245/35/19's (lowered) is +40ET. Pokes out enough to look good, but not enough to induce rubbing. If you're looking to be "flush", I would think around a 28-32 ET would get that look, depending on the tire size, of course.
Kind of a crappy picture, but this will give you an idea of how a square setup; 8.5 45ET with 5mm spacer (effective 40ET) looks as a side profile. Keep in mind this is lowered. On stock suspension, it will not look as flush as it does here.
