How to connect to positive lead of reversing lamp
I just purchased a dash cam. I only plan to mount the rear camera inside and use it only for recording. But it needs to be connect to the "positive lead of reversing lamp".
I have never worked on a car. Does anyone have some instruction / photo / video how to do that on C300?
I'd want it to be able to record when the car turns on, not just in reverse gear. What should I look for to connect the wire too? I don't really know cars so any visual information would be appreciated
https://www.youcanic.com/guide/2015-...c-trunk-fuses-
You'll need a test light and a fuse tap kit, then just run the wire through the corner of the back seat to get to the rear deck. I would test this setup before mounting everything, not familiar with your kit but having a "constant-on" reverse signal may cause input confusion.
