C300h no Start/Stop
I searched and seems that the Auxiliary Battery is the main cause for this issue, I wanted to know how hard can such thing to replace my self and is the location same as a c300? or its on a different as I cant find anywhere anything that says soo.
And maybe just charging it coud that fix it or needs replacment at all?
On regular w205, eco start/stop isn't functional when the battery is under 80% and you already know about the aux capacitor.
So I am thinking similar principal applies to the hybrid, because yours is usually at 60-80%, eco start stop not kicking in.
Do you remember what the hybrid battery level was usually at when the car was brand new?
In my preferred “C”, it starts and runs up to about 15mph (on light throttle) before the diesel engine starts or cuts in. The exception is ambient temperature extremes when either high A/C or heat in the cabin is required. Otherwise, pressing the start button, you get the green “ready” light and off you go, on electric motor.
wont to create new post, so writing in here..
have w205 300h and still cant to fix issue with eco start/stop function .. its still not working at all like hybrid system too...
i have changed:
both new battery's (but aftermarket)
main battery terminal with sensor
aux battery relay
decoupling relay
but in the cluster BN rate cant to reach 100%, max is 92%.. second BN reading in eco mode is 11 max ..
BN in the cluster shows aux battery or main battery readings?
xentry doesnt show any faults...
try to change front SAM? CDU?
