C300 makes weird noise while changing between gears
My c300 2017 makes weird, clicky noises when i change it from P to D or D to R for example. Is this a normal thing that happens with you guys? Is is something with the transmission fluid?
Received 2,473 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Hey thanks for the reply, i have attached the video, the car makes this weird clicky sounds and Im just worried if it could be a bigger issue that Im unaware of
https://drive.google.com/file/d/1DRprpcbFShsvSO9-4doaedxQSQ2zJ7TW/view?usp=drivesdk
1986 Light Ivory R107 560SL, 2020 Lunar Blue W205 C300 AMG-line
Mine with the 9 speed does this sometimes as well. I think it is the electronic parking brake stopping the car from rolling when you put it in gear creating a bit of a pop due to the tension. Try releasing the parking brake first and see what happens. Back in the 80s with the old 4 speed, MB used to recommend in the owner’s manual to put the car in neutral for a second or two before selecting your gear to reduce wear on the transmission and prevent it from popping.
https://drive.google.com/file/d/1DRp...w?usp=drivesdk
