Removing rear vents
Old Jul 11, 2021 | 09:43 PM
ctsvette's Avatar
C8 Z06, Mercedes C43 sedan, Jeep Grand Cherokee
Removing rear vents
Does anyone know how to remove the rear vents? I've been doing an LED vent install and am pretty much done but but I cannot for the life of me get the rear vents console out. I was able to get the top part to pull out but the rest of it refused to come out and I don't want to break the entire thing. I've watched flexes video and it seems to come out really easy and I can say mine is not. Anyone have any experience? Thanks!
Old Jul 12, 2021 | 07:47 AM
Andy74's Avatar
W205 2015
It looks like you need to push a little bit as seen below:
Old Jul 12, 2021 | 08:39 AM
ctsvette's Avatar
https://youtu.be/uTYERek5xDQ
My car is the 2021 sedan, so it may be different as mine doesn't have cup holders up there. Also, when the top popped out on mine there was only about a half inch separation and it wouldn't come out any more.
Old Jul 12, 2021 | 09:57 AM
Andy74's Avatar
W205 2015
I wonder what model year is the car in the video Mine is a 2015 the cup holders are found in the rear armrest. 2021 is like very recent how about you take to a professional shop? Are u removing those to install the LED turbine air vents?
Old Jul 12, 2021 | 12:40 PM
ctsvette's Avatar
Yes, it's to do the ambient light vents. I've done everything else but haven't figured out how to remove these.
Old Oct 14, 2021 | 04:11 PM
Moe777's Avatar
W205
did you connect yours? Same problem here, did you connect them to center console? If so how?
Old Oct 15, 2021 | 07:22 AM
ctsvette's Avatar
Yes, I was able to get them off. If I remember correctly you have to pull really hard pull out and up after the top comes off. It took quite a bit of force, but then breaks free.
Old Oct 15, 2021 | 08:54 AM
Moe777's Avatar
W205
thank you, may i ask where you connected them to? Below passenger seat or center console?
Old Oct 18, 2021 | 07:33 AM
ctsvette's Avatar
I connected them to the front center console ran the wire along the outside edge and tucked it under the center console.
