Deceleration using paddles
So is it ok and not harmful to use the paddle shifters to decelerate/brake? This would be within reasonable rpms. Just wondering if it's a nice way to save on brake wear.
Thanks!
When I first bought my C300 I did downshift on downhill grades and when coming to a stop but quickly found there is almost no engine braking available with this engine.
Seriously, how much more wear on the brakes do you think will happen compared to when downshifting?
Having said all that, as one person mentioned above, turbo charged engines have less engine braking due to the lower compression ratios, especially small turbo charged engines, so you might not slow down very much by just using engine braking, or you have to downshift into a really low gear before you get decent engine braking.
All said, brakes are a designed wear and tear item just like tires. Use them, replace them.
