2017 c300 base coupe diffusser?
2017 c300 coupe
Hello,
Im new to the benz world. So i purchased a 2017 c300 base coupe thinking i can upgrade the exterior. I havent been able to find a rear diffuser thats a direct bolt on to the base model. Can someone point me to the right direction, if there is one.
2017 c300 coupe
2017 c300 coupe
If thats the case then ive been wasting my time. But the front and rear bumpers look different, not sure if they have the same dimensions or mounting clips.
Front bumper however is I'm pretty sure exactly the same as any other AMG Line 205 bar the C63.
2017 c300 coupe
Thats my problem, i cant find a rear diffuser that will fit on a non sport/amg rear bumper.
https://www.aliexpress.com/item/1005002976393943.html
https://www.aliexpress.com/item/32982137453.html
And more and more and more, there is loads on Ali, I'm sure you'd be able to find local resellers for these as well.
2017 c300 coupe
https://www.aliexpress.com/item/1005001444339919.html
If you however have any other trim of the car then you should be able to use any of the AMG diffusers.
2017 c300 coupe
After some more research I can now see the Sport trim (in UK at least) of C205 is actually avantgarde styling on a Coupe. If that's the trim of your car then you're out of luck, the only way around it would be a custom job or change the entire bumper with an AMG line one.
Yeah, you have an avantgarde styling on a coupe which until today I believed didn't exist. I'll refer you back to my previous post for the only solution as I cannot find anybody that does any different diffusers for those.
2017 c300 coupe
Well thats awesome news, really appreciate your help.
