Brakes Vibrate when braking at low speed
Old May 25, 2023 | 09:14 AM
kluciano's Avatar
W205
So I have a 2019 C200 (W205) and my brake vibrates a little when I am driving and going to a halt from like 1mph (1km/h) to 0 (to stop) it likes to vibrate a little and gives off this grinding sound. At first the suspect was the brake pads and brake disk, I have replaced both brake pads and brake disk with genuine Mercedes parts, and the sound has lessened but it is still vibrating and giving off a grinding noise. Does anyone else ever experience this?
PS: I was told by my local Mercedes dealer (Jakarta, Indonesia) that it was a trait of Mercedes brake. I used to own a 2016 C-class and 2017 E-class and they do have some noise when the brake got wet from rain but it was never a vibrating and grinding noise.
Old May 25, 2023 | 02:29 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Hmm, my brakes squeal loudly in winter when I reverse. it been doing that since I got it 5 years ago. Mentioned to the service guy many times. He just shrugs.
Lately, I too have noticed a tiny vibration in the steering wheel and brakes when slowing down to a light. Mentioned to the service guy. Says technician found nothing wrong. No grinding noise tho.
I got brand new brakes when I purchased the car 5 years ago and they have never been changed since. Is that even possible?
I do work from home (mostly) and then there was the pandemic (2 years), but brakes lasting that long?
Old May 25, 2023 | 06:52 PM
W205C43PFL's Avatar
I mean... what is your mileage, mainly highway driving? Stop and go will eat brakes.
Old May 25, 2023 | 07:11 PM
superswiss's Avatar
2019 C63CS
The Mercedes OEM rotors take special care to install and are somewhat sensitive to damage. The hat of the rotor is a separate piece made from 5 mm steel sheet. If not handled properly it can bend and bring the rotor out of alignment. Several typical things are not allowed such as using a hammer to bang the rotor and trying to rotate the wheel by holding the disc. I suppose road force could potentially bend it to. The result is rotor runoff that will cause vibration. Commonly diagnosed as warped rotors. Below is a video that addresses what to look out for when installing the brake rotors on these cars. The video is primarily about Conti aftermarket rotors that eliminate these issues. I know the video is in German, but it's supposed to have English subtitles.
Old May 25, 2023 | 07:29 PM
benzdude's Avatar
Top Answer: 1
My brakes are all Mercedes service installed and inspected. Plus they keep telling me they are fine.
Old May 25, 2023 | 08:33 PM
superswiss's Avatar
2019 C63CS
Which is not unusual. Ask them if they measured rotor runout
