W205 vs W204 Oil Change
I can drain the oil and remove the filter on my Boxster without raising the vehicle. I can do the same with my wife's Nissan Murano, where the engineers cleverly designed a hinged panel in the undertray to allow the oil to be drained without removing the under tray. It's MB. They are smart people. They can make it easier.
let's see if we can help you out by telling us model car and engine you have? Dipstick and oil filter circled in red, this gas powered c300, 205-20212
My signature has the year and model (2020 C300 M274). There is no dipstick. Here is a picture of the engine with the vanity cover removed.
Alynch, I normally service (minor services), all of my vehicles myself, but not my W204 (C63), as it is to low slung to get under it.
I get a mate/Mechanic Gus and Johnny to service it.
When doing an oil change this includes putting the vehicle up on a hoist, removing the engine sump plug, and also draining the engine Oil Cooler.
Draining the Oil Cooler, is something it would appear, even the local M-B dealerships don't do!
The other thing these good tradesmen do, is they let the old oil drain for 5 minutes-ish, prior to replacing both the sump plug and oil cooler crush washers, and tightening things up again.
Also, I'm not sure what the Imperial (Quarts) equivelant is, but my C63 requires 8.5 liters of engine oil, when both the engine/oil filter, and oil cooler are all drained/replaced.
I hope that helps.
Regards Homer
Good to hear, that you have got on top of this.
Yes, Gus and Johnny are not only great blokes, but great Mechanics as well.
I could say more about the M-B service manuals, but let's just say, they put a lot of effort, into placing useful information in them.
Avagreatweekendeh!
Homer
by your own words the folks at MB are a smart bunch. So it’s fair to reason then that perhaps removing the dipstick in favor of a more traditional method was not necessarily an arbitration.
Regardless, it is unfortunate that this shortcut no longer exists on the M274 for you. In the end, it’s a pretty standard procedure that many DIY’ers probably appreciate as it no longer requires a mityvac or equivalent. Pros and cons.
As an engineer, I will say that the flow of solids within a fluid is a complex affair and it is much more fail safe to do an oil change the traditional way. I understand that you’ve never had an issue but one personal account does not a general rule make.
Another benefit I can see from bottom draining is that if you drop the body cover, you can also have a chance to inspect for any leaks.
Good luck to you.
