2016 c300 w205
Old Feb 22, 2024 | 04:18 PM
Nico Candelario's Avatar
Veteran: Marine Corps
2022 E350 Benz
Question 2016 c300 w205
Alright guys I messed up, smh I always do my oil change my self and get the recommended 0w-40
and today I screwed up and put 5w-40. What do you guys recommend? Do you think it will hurt the vehicle this one time?
I change oil every 5k miles and I live in Fl. I keep reading mix reviews that the oil I used 5w-40 is fine just don’t make it a habit. Any insight would be great thanks guys.
Old Feb 22, 2024 | 04:24 PM
chassis's Avatar
2017 GLE350 4MATIC
Don’t worry.
Old Feb 22, 2024 | 04:28 PM
2022 E350 Benz
If they were slightly mix should be no issue either ? Thanks man for you for the responce
Old Feb 22, 2024 | 06:09 PM
Keith66's Avatar
2018 AMG E43
Agreed, you're totally fine. No worries. The difference between 0-40 and 5-40 are somewhat negligible.
In fact, I think you screwed up in the right direction, lol. I'm in Florida and I run 5-40 because between the two, zero weight is suited towards better flow in low temperatures and 5 weight is suited more towards higher temperatures, like Florida.
I say you did the right thing!
Also no need to worry about mixing these weights because they are so close in specs.
Old Feb 23, 2024 | 12:40 PM
Cosworth2000's Avatar
2022 E53 AMG
You are okay.. our engine - V6 Turbos use both 0-40 and 5-40.. Winter is 0-40 and Summer is 5-40.
From what I read, the engine will be okay unless you have express cold.
Edit to fix the information
Old Feb 23, 2024 | 12:42 PM
2022 E350 Benz
Originally Posted by Cosworth2000
You are okay.. our engine - V6 Turbos use both 0-40 and 5-40.. Summer is 0-40 and Winter is 5-40.
I got a 2 liter turbo charge engine 4cylinder tho? Not v6
Old Feb 23, 2024 | 12:51 PM
2022 E53 AMG
Don't worry, you will still be okay. If you look in the service good, you will see that you can also use that rating which is not to far off the 0-40 ratings.
Old Feb 23, 2024 | 12:52 PM
2022 E350 Benz
Oh ok great yea all these guys at orileys and tire kingdom when ask suggest to switch it out that they wouldent risk it but I’m like it can’t be that bad for 4K miles till I change again. thanks again for your time have a good weekend
Old Feb 23, 2024 | 02:22 PM
Keith66's Avatar
2018 AMG E43
...snip
snip...
This is probably an honest mistake, but I want to clear it up for others that may come across this. It's actually the other way around.
0-40 is more suitable for colder climates.
5-40 is more suitable for warmer climates.
But as said, it's not all that crucial unless you are running at great extremes with heavy duty cycles.
