Mercedes C300 - Transmission shifts hard
Old Feb 25, 2024 | 03:08 PM
mercedes-dan's Avatar
C300
I bought this used car (2015) about a month ago from the local MB dealership.
The problem started while exiting an extremely challenging driveway onto a busy road. (Driveway is a couple inches higher than the road, requires a sharp 90 degree turn and then quick acceleration). Every car I've ever driven on this driveway 'feels' likes its, torquing the frame, and the tires always chirp on it.
Immediately exiting the driveway, the transmission seemingly got confused, shifting in-between gears extremely hard and somewhat erroneously. The gear switch is so hard my neck is slammed forward then backwards, slamming into the head restraint quite hard. No warning/error messages appeared on the screen.
This problem mostly occurs in Sport mode and with fast acceleration. It's been on Comfort mode for the last 300 miles (driving in-between Houston and Austin, and all around town) and have had no problems with the transmission.
What could the matter be, and it's fix?
UPDATE: In hindsight and retrospect, I was switching drive mode from "C" to "S" at, or within a fraction of a second of, that challenging driveway, never having coming to a full stop. And the problem only happened on that one day 2 weeks ago, has not reoccurred, I can't get it to reproduce. Perhaps I just confused it's computer one day?!?! 🤦‍♂️ Like fixing computer problems.. just restart it. I'm good with crashing computers. IDK.
Last edited by mercedes-dan; Feb 25, 2024 at 08:55 PM. Reason: Intermittency update
Old Feb 28, 2024 | 06:57 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Your car is a W205, not a W203. People here won't be able to help you unfortunately. Different transmissions.
Requested to move this thread to W205 forum.
Old Mar 1, 2024 | 03:20 AM
Wolfman's Avatar
Super Moderator
Thread moved
Old Mar 4, 2024 | 07:44 PM
Star300's Avatar
W205 C300 Base
i have a 2015 too and i thought i had a transmission problem as well about a year ago, even brought it to a mechanic but he said it was fine. you can reset the transmission i forgot how but apparently it knows how u drive and drives accordingly
Old Jun 10, 2024 | 12:18 AM
C300
I thought the same ... somehow. Like.. somehow .... IT KNOWS how u drive and it adjusts accordingly.
Previous owner drove it as a sedan... current owner a MANiac ,, if I'm mansplaining correctly.
I drive it normal - it acts normal. I drive it like me , problems persist.
Old Jun 10, 2024 | 12:22 AM
Star300's Avatar
W205 C300 Base
it’ll turn itself out, i heard those transmissions are really over built and one mechanic that’s worked on thousands of mercedes with that transmission told me he only seen 4 with major issues. sadly i crashed my w205 😞 hope you enjoy yours, those cars will last a while with proper care.
Old Jun 10, 2024 | 07:34 AM
W205C43PFL's Avatar
Honestly, MB transmissions are very reliable in general it is just that the software and the hardware apparently speaks different languages, it is a luck of the draw, some are programmed better, others not so much. Mechanically they are reliable though.
Old Jun 11, 2024 | 04:45 PM
C300
PROBLEM SOLVED. Or at least FOUND. It finally occurred again yesterday ... after 4 months of no problem... and finally produced an Engine Light & Error Code:
P0339- the crankshaft position sensor electrical circuit was intermittent for a predetermined period of time.
Just brilliant German engineering... I love how it automatically goes into 'limp mode' or 'protection mode' after this ... limiting RPM and downshifting. Amazing!
$39 plastic tube lookin' device.
It only happens on those pesky 90^ driveways with asphalt height differences. Disconnect battery for 10 minutes. Problem solved.
The cars work FINE .... onto fixing our roads. 🏁
Old Jun 11, 2024 | 04:53 PM
C300
https://www.benzworld.org/threads/p0...ttent.3107543/
Old Jul 1, 2024 | 08:42 AM
C300
Update: FIXED. Mercedes dealer is soooo awesome. They drove a brand new Mercedes (A220) to my house, traded cars, he drove mine to the dealer and they repaired it. Best to take the car in for repairs on a Friday afternoon - free new car for 4-5 days. The new Mercedes is exquisite!
I called in advance - they had 3 sensors in stock - $67 part. A few more hundred all in.
The car runs fine now; and best of all, it's getting used to my driving style.
Old Jul 1, 2024 | 08:57 AM
W205C43PFL's Avatar
Wait... you like the A-Class more than the C-Class???
What did they fix/changed? Do you mind posting the work order or at least part of the work order that shows what they done and the parts replaced with the part numbers, thanks!
Old Jul 1, 2024 | 11:10 AM
C300
Q: Wait... you like the A-Class more than the C-Class???
A: Haha... No way!! While the 2023-2024 A-Class only had better inside Ambient Lighting, and reverse camera... my ole 2015 C300 was better in EVERY. Single. Other. Way. I LOVE this car!
Q: What did they fix/changed?
A: Just that one single sensor.
Q: Do you mind posting the work order or at least part of the work order that shows what they done and the parts replaced with the part numbers, thanks!
A: Picture of the receipt showing "service name" attached. Picture of codes from video screen grabs.
And here's a great video the tech sent (it has part numbers, codes, history of same issue in 2017, recommendations, fixes, etc. etc.).
I covered the VIN in the video.
He busted me for having someone else test wire voltage (by crimping) and then replaced H.P. fuel pump.
Just awesome work by Mercedes dealer service center.
Old Jul 1, 2024 | 11:38 AM
W205C43PFL's Avatar
youtu.be/Zu-Bsfs10oU
https://cimg0.ibsrv.net/gimg/www.mbw...12c371e841.jpg
https://cimg1.ibsrv.net/gimg/www.mbw...85c4874fe0.jpg
Thanks for the detailed information, I am glad to hear you are enjoying the W205 and now with the issue out of the way, you can enjoy it even more now. So please enjoy in good health!
