Dynamic Select keeps resetting (to comfort) itself while driving
Old May 11, 2025 | 06:55 PM
W205C43PFL's Avatar
I can't tell, is this car tuned? It's likely the engine torque fault that is causing this. Something's wrong with your tune/engine, so it can't correctly determine the amount of torque it makes and therefore it likely reverts to the Comfort throttle map as a precaution as that is the safest throttle map. You gonna have to sort out why you are getting these faults. If the engine is tuned, then it's likely an issue with the tune. If it's not tuned then something else is going on, such as a faulty sensor.
OP stated repro(grammed?) for more horsepower and torque: https://mbworld.org/forums/c-class-w...ml#post9158917
Sounds like another word for tuned to me.
Old May 12, 2025 | 01:42 AM
gadnyara's Avatar
C220d 2019
U016887 - Communication with electronic ignition lock has a malfunction
Have to resolve the communation losts...
It is like restart(s) of engine, result - goes to Comfort.
It can be coded to 4 hours memory of chosen mode (for 9G box).
Should mask the problem...
Old May 12, 2025 | 02:44 AM
GabrielFSousa's Avatar
c205
yes, is tuned.
Old May 12, 2025 | 08:18 AM
W205C43PFL's Avatar
This code doesn't have to do with OP's issue though, I seen many W205 have this and it is a stored code but it doesn't actually affect the functionality of the vehicle. The fix for this was simply a software update via XENTRY.
Old May 12, 2025 | 08:20 AM
W205C43PFL's Avatar
Found a XENTRY TIPS document for that code actually, again, nothing to do with OP's issue and can safely ignore without impairing the vehicle's function.
File Type: pdf
Old May 12, 2025 | 09:24 AM
Cosworth2000's Avatar
2022 E53 AMG
This is all beyond my think path.
Old May 12, 2025 | 04:58 PM
  #32
W205C43PFL's Avatar
It is strange how OP's tune caused this behaviour but from the other thread, MSL tune could possibly cause this issue.
Old May 12, 2025 | 05:08 PM
  #33
c205
my GOD, found out the issue.
i have an android unit with SIM card, and i also have the GSM antenna, but was the worse place possible, too close to the NTG and the back cables.
now is far away possible from NTG and never got the issue again
Old May 12, 2025 | 05:36 PM
  #34
superswiss's Avatar
2019 C63CS
Serves as a reminder to always provide the full picture when posting about issues. More often than not, problems are caused by aftermarket modifications, especially electrical issues. I didn't even realize that you are the same person who is having issues with the flickering video and sounds like it was due to the same issue. First place to start with any random issues are the aftermarket modifications.
Old May 12, 2025 | 05:47 PM
  #35
c205
this one was not easy. Because the issue was caused by Electromagnetic Coupling ... and NOT by any equipment malfunction / bugs / software... the solution was just to move the GSM antenna has far away from NTG
Old May 12, 2025 | 05:54 PM
  #36
superswiss's Avatar
2019 C63CS
Same thing. Interference from aftermarket equipment is not unusual. As an electrical and computer engineer I can tell you that signal interference can cause all kinds of random issues. I'm surprised that the vendor of this Android Unit didn't point out to not place the GPS receiver too close to existing components.
Old May 12, 2025 | 06:16 PM
  #37
W205C43PFL's Avatar
https://cimg9.ibsrv.net/gimg/www.mbw...0d504ac3d9.png
wow never would had thought about that (as in interference) , glad you figured it out yourself and thank you for posting your findings.
Old May 12, 2025 | 06:19 PM
  #38
W205C43PFL's Avatar
What about OP's stored code though, isn't that still related to their tune?
Old May 12, 2025 | 06:44 PM
  #39
superswiss's Avatar
2019 C63CS
Possibly, unless the GPS receiver interfered with the ECU etc. as well.
Old May 12, 2025 | 06:48 PM
  #40
W205C43PFL's Avatar
Hmmm true, will need OP to reply if there is still a problem with power delivery.
Old May 13, 2025 | 03:21 AM
  #41
c205
for GPS im using car antenna, i used a splitter cable. car GPS and android GPS are both working
in 2021 i asked to a company to tune my car, thats why i have the error message, i have to fix that too
Old May 13, 2025 | 04:10 PM
  #42
W205C43PFL's Avatar
So that code does have to do with the tune hopefully they figure it out, what is the tuning company?
Old May 13, 2025 | 04:42 PM
  #43
c205
a small company here in Portugal
Old May 13, 2025 | 05:22 PM
  #44
W205C43PFL's Avatar
I see, hopefully good customer support and works with you with getting it solved.
Old May 23, 2025 | 04:54 PM
  #45
c205
In my opinion, one of the noblest things a human being can do is share information.
so, heres more information !
the cell phone in that area was also causing my Dynamic Select resetting
putting the phone in the door, my Dynamic Select never reset again.
Old May 23, 2025 | 05:00 PM
  #46
W205C43PFL's Avatar
That is some strange interference since I always put my phone in the cup holder and never have issues. That looks like a Oneplus phone (the never settle was their slogan), they were once a big hit in Canada and now there are too many options (talking about Canada specifically).
Old May 23, 2025 | 05:02 PM
  #47
c205
its the google pixlel 7 pro, i changed to 4G
before that i had a oneplus 9 pro, and with that phone i had no problems.
maybe gsm from pixel 7 pro is stronger...
Old May 23, 2025 | 05:13 PM
  #48
W205C43PFL's Avatar
How come it still says never settle? Did you just transferred the settings over from oneplus hence why it shows that? They used to market all over the place here in Canada, looks like this, never seen the company ever again in the recent years: https://images.fonearena.com/blog/wp...ver-Settle.jpg
So you tried 5G and it still interferes with it?
Old May 23, 2025 | 05:20 PM
  #49
c205
i use custom roms , ehehehehehe
https://xdaforums.com/f/google-pixel.../?prefix_id=33
i will try using 5G, and will report
Old May 23, 2025 | 06:12 PM
  #50
W205C43PFL's Avatar
Ah you like modding your phone, gotcha, that might explain it if you used a oneplus rom or something.
Sounds good hopefully 5G solves your issue.
