No AC Pressure after compressor replacement
Is there some magic Mercedes trick to getting this to work?
Thanks.
Thanks.
It's not pumping down low side into high side pressure regardless the fact its spinning.
Double-check that replacement is really compatible, suspect new proportioning valve of new compressor is the wrong type (diode vs. no-diode)
It is spinning but not building any head pressure.
Look at the governor valve duty cycle
Look at the clutch activity !
look at the condenser pressure sensor
Resist the urge to overfill. 75Psi should allow pumping.
I don't see how I can overfill it when the compressor isn't pulling down the low side? It's reaching can pressure and that's it. I have no way of pushing more refrigerant in it.
Thanks for the info though!
I'll post what the ultimate issue was.
With both Hi/Lo equal pressures your compressor is not pumping.
The A/C shop will get this sorted in no time.
Let's see....
There is something else very easy you can do in that department : waterproof the connections to your A/C compressor.
You can see compressor from the wheel well where it gets sprayed with road elements - The two connectors are not waterproof - Apply engine RTV where wire harness enter the back of each plastic connector.
Enjoy.
Enjoy.
Wheel well view of exposed A/C connections
This electrical failure is not as random as my thoughts.
These use connectors directly exposed to road spray.
Each individual wires act as a guide to channel water inside the connector onto the tinny oxidized pins. This guarantees poor connections.
I seal the external junction of wire to connector.
Whatever seals the water out...
