2022 lack of USB ports!
Issue with MB dash cam
I opted for a U1000 front and rear dash cam for one main reason. The MB dash cam required you to start it on every trip, probably for privacy reasons. My U1000 w/ an aux battery runs continuously with a parking mode supported by an aux battery. Once you start the car it automatically begins filming.
Just make sure it's enabled.
If plugged in and USB is live -- there will be drain after car is turned off
If the USB is live after the car is turned off, then the device will be live and draining the battery. The amount of drain depends upon the actual device that is plugged into the USB.
alexasa (05-10-2023)
#35
Where did you connect these too
Hi could you please let us know how and where did you connect all of these together
Tony
Tony
i found a way of splitting 1x usb-c into 2 (1x power passthrough for chargers etc and 1x data for music on usb)
i tried a usb c splitter but apparently its really hard to split the power from data on usb c type
ill post the items i bought below:
1x usb-c to usb adapter cable
2x usb Y splitter
1 x usb to usb-c
this will now let me use a usb-c wireless charger AND a usb stick with music on .
usb hubs just dont work on the newer mercs
2x usb Y splitter
1 x usb to usb-c
#36
Autostart seems to be country dependent. The whole dashcam feature is country dependent but without any good reason. Try to push your dealer to really figure out why the option does not work for you. UK should be same as existing EU countries but it even varies between EU countries (i.e. autostart missing in some countries that have the dashcam feature, some have it). Different legislation does not explain this.
#38
I wonder if this GLE ports will fit it looks about the same size/shape
https://www.ebay.com/itm/12601977267...4aAtAjEALw_wcB
#39
