C-Class (W206) 2021 to
Rear tinting issues - due to moisture in trunk
Old Sep 29, 2022 | 05:09 PM
GMF's Avatar
GMF
C300
Hi All,
I understand reading from existing thread that certain models of C300 had issues as a result of the water entering the electronics in the rear trunk. I think the issue had been addressed in cars produced after June (not sure exact date)
Wondering if anyone has encountered similar issues on more recently produced C300's?
Old Sep 29, 2022 | 05:16 PM
W205C43PFL's Avatar
Originally Posted by GMF
Hi All,
not sure which thread you read but in case you missed this one (or this post specifically) it is a bulletin to address this issue. https://mbworld.org/forums/c-class-w...ml#post8637797
To answer your question if anyone has encountered similar issues on more recently produced ones, yes. Thankfully, if you go to a shop that has experience with this and takes enough precautions, you will likely be fine.
Old Sep 29, 2022 | 06:14 PM
GMF's Avatar
GMF
C300
Thanks - I was referring to a article that was linked in the thread you had shared - Post #78.
Like you said - I guess would probably have to take it to a place that has experience with similar models. Taking it back to the dealer for Tint is expensive!
Old Sep 29, 2022 | 07:49 PM
W205C43PFL's Avatar
From what I heard, some dealerships actually refuse to offer tinting for the W206 until they have performed this cover retrofit, I don't think they trust themselves either.
