C-Class (W206) 2021 to
DIY Videos
Old Apr 14, 2023 | 03:01 PM
giovane's Avatar
2023 C Class
DIY Videos
Has anyone started a DIY Video thread already?
Here's the few ones I found on Youtube so far:
Pollen filter change (in German, but very self explanatory)
(this guy has several videos on his channel but I haven't checked them all - his full w206 playlist is https://www.youtube.com/playlist?lis...mZlM1Qaf5T8xW6 )
Oil change
Head unit removal
If you find more, please add to this thread
Old Apr 15, 2023 | 07:38 AM
W205C43PFL's Avatar
https://www.youtube.com/watch?v=Cn-zVsbdN88
Oil change
https://youtu.be/L42PBi7R2Mk
Head unit removal
https://youtu.be/MT0HBm8tjg8
Awesome to see thanks OP
Old Apr 16, 2023 | 02:26 PM
giovane's Avatar
2023 C Class
Door panel removal - replace window switches
Door speaker
Old Apr 18, 2023 | 02:57 PM
giovane's Avatar
2023 C Class
Tech menu (it works, but I haven’t tried to change anything)
Old Apr 20, 2023 | 09:12 AM
W205C43PFL's Avatar
https://youtube.com/shorts/nvSUfaBIAts?feature=share
Whatever you do don't hit the reset all function. It makes your car forget what software options it has so it will render your parktronic, cameras etc that base car have inoperable.
Old Apr 22, 2023 | 03:43 PM
giovane's Avatar
2023 C Class
Removal of back bumper - this video is in Chinese but you can figure out the process
Service reset
Old Apr 23, 2023 | 06:44 PM
W205C43PFL's Avatar
https://www.youtube.com/watch?v=Vrg0XJAjpLs&t=81s
Service reset
https://youtu.be/oWSQPAesOWA
Thanks OP, keep the videos coming.
Old May 20, 2023 | 04:58 PM
giovane's Avatar
2023 C Class
Replacing the front camera
Old May 23, 2023 | 10:29 AM
W205C43PFL's Avatar
https://youtu.be/g0jZ85aziO4
Thanks OP.
Old May 27, 2023 | 09:51 AM
giovane's Avatar
2023 C Class
Removing the front bumper
Old May 27, 2023 | 11:59 AM
W205C43PFL's Avatar
https://youtu.be/1trurGsTvJY
This thread is a gift that keeps on giving...
Old May 28, 2023 | 12:26 AM
giovane's Avatar
2023 C Class
Replacing front brake pads
Old May 28, 2023 | 10:49 AM
W205C43PFL's Avatar
https://youtu.be/7KKXMNipqu4
Thank you
Old May 29, 2023 | 03:26 AM
HumbleBy's Avatar
W206 C300
And here is a brake pad replacement video if your car is fitted with the sport front brakes. The video says W205, but I believe the sport brakes are exactly the same on the W206. They look completely identical to the sport brakes on my C300.
It is possible to replace the brake pads without removing the caliper, but in the video here, the rotor is also replaced, requiring removal of the caliper.
Old May 30, 2023 | 08:25 AM
W205C43PFL's Avatar
Front brake pad replacement - sport brakes
I see, that makes it easier then.
Old May 31, 2023 | 07:12 AM
818benz's Avatar
2025 C300
Thank you!!!! Just changed the oil and reset computer myself thanks to you @giovane
Old Jun 3, 2023 | 11:59 AM
giovane's Avatar
2023 C Class
Replacing the grille
Old Jun 3, 2023 | 01:04 PM
W205C43PFL's Avatar
Thank you.
Old Jul 22, 2023 | 11:35 AM
giovane's Avatar
2023 C Class
Disassembling rear vents
Old Jul 24, 2023 | 07:21 PM
W205C43PFL's Avatar
https://youtu.be/NhW4x2HbMV8
Useful thank you.
Old Jul 29, 2023 | 09:05 AM
giovane's Avatar
2023 C Class
Removing the center console (thanks Chesttechner as always)
Old Aug 5, 2023 | 04:37 PM
giovane's Avatar
2023 C Class
Replacing rear vents with led illuminated ones
Old Aug 12, 2023 | 10:08 AM
giovane's Avatar
2023 C Class
Rear bumper removal
Old Nov 8, 2023 | 10:34 PM
Rico30555's Avatar
w206 C300 4matic
Did you use a jack stand or ramps? im going to do one myself but I see theres only 4 jack points trying to get the front wheels only off the ground on stands
Old Dec 9, 2023 | 09:18 AM
giovane's Avatar
2023 C Class
For those who want to try to fix the passenger seat rattling noise themselves, here’s a video on how to remove the back seat panel (thanks to Chesttechner as always)
youtu.be/SBhv7gppzBk?si=FdlO0pfHGJSwOaFj
