C-Class (W206) 2021 to
Engine temps
Old May 22, 2025 | 10:21 PM
Steely's Avatar
C300 W206 2022
Once you activated service menu, it won't hide it until next ignition cycle. Doors needs to be closed, windows, trunk, hood, windows. Key in position 1 (1 press without foot on brake) and display needs to be showing trip with odometer.
The workshop menu hides with a back arrow press, if I understand your comment correctly
Old May 22, 2025 | 10:28 PM
W205C43PFL's Avatar
Originally Posted by Steely
The workshop menu hides with a back arrow press, if I understand you comment correctly
It will be gone next ignition cycle, you can feel free to exit the workshop menu as many times as you want until you turn off the engine, then you will need to activate it again before starting the engine to have it there again.
Old May 26, 2025 | 04:11 AM
Felix2024's Avatar
W206 C200 4Matic
Originally Posted by Thekiller114
I checked today and scrolled up and down like 20 times but didn't find anything
Yeah i scrolled till i reached the original page like 20 times but didn't find it if you would kindly send a pic of what's showing up in your car so i can compare it to mine
I was wrong about where it is. It is fourth screen from the bottom.
It show exact oil level and oil temp. Photo taken after turning off the ingition, that's why it's not showing oil level.
Old May 26, 2025 | 02:25 PM
W205C43PFL's Avatar
Sweet you found it : )
Old May 26, 2025 | 02:26 PM
W205C43PFL's Avatar
Thanks again to the other forum member for helping OP find this information. Case closed : )
Old May 27, 2025 | 03:34 AM
Felix2024's Avatar
W206 C200 4Matic
Actually case is not closed
I'm not the OP, just attached the picture of how it looks in my car, by OP's request.
But we still don't know if this info is available in OP's car, or were there any software changes in the meantime, which removed this from newer cars.
Old May 27, 2025 | 10:12 AM
  #32
EleBest's Avatar
SPONSOR
E200 2010, G63 2018, E53s 2019, EQS53 Touring 2021, S500 2022, A200 2023
you can get this coded, so you will be able to check engine oil temp and gearbox oils temp anytime you want.
this is included in our AMG Coding Package as in the video below:
feel free to contact us to get yours done.
https://wa.me/6597335000
Old May 27, 2025 | 04:25 PM
  #33
W205C43PFL's Avatar
Oh oops I mixed things up.
Old May 27, 2025 | 04:27 PM
  #34
W205C43PFL's Avatar
Originally Posted by EleBest
https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x922/a1a851c5_91e9_4c26_827a_1aece9125104_7c8f36040c353 5a573fc205b3c69b6f7b6d0345b.png
https://youtu.be/ChXgGk9pq_U?si=reWYJzILl0Pi_KGP
That might be viable for OP.
Old May 29, 2025 | 05:52 PM
  #35
Thekiller114's Avatar
c 300 w206
Thanks for the pic but that's weird that MB would have different workshop menus for different cars maybe its just a region thing i guess my only option is coding
Old May 29, 2025 | 06:12 PM
  #36
W205C43PFL's Avatar
Sorry, which pic are you talking about if you don't mind me asking?
Old May 29, 2025 | 06:28 PM
  #37
c 300 w206
This pic
Old May 29, 2025 | 07:25 PM
  #38
W205C43PFL's Avatar
This pic
I see. Strange.
Old May 30, 2025 | 03:34 AM
  #39
Felix2024's Avatar
W206 C200 4Matic
Well, wouldn't be the first manufacturer who does that
Maybe the fact, that i have AMG package is changing something?
One question - do you have a screen with oil level at all?
Old May 30, 2025 | 09:28 AM
  #40
c 300 w206
I do in the service screen only not the workshop menu but i have something that says oil level in the workshop menu but when i click it it says has engine oil been added and im scared to say yes so i click no and it just takes me back to the main workshop menu
Old May 30, 2025 | 09:49 AM
  #41
Felix2024's Avatar
W206 C200 4Matic
Ok, that's interesting.
I have this screen which i showed on the pic. It shows oil temp, but most important info is exact oil level, shown with 0.1L resolution.
I would assume all cars should have it to show exact oil level, since we are missing oil stick for "old time" oil level checks. But might be wrong, and not all cars do?
The one in the service screen is not really good. After last maintenance at dealership, it was showing full/max, but in the workshop menu it showed only 5.4L, where max is 6.0L.
Just to make sure - there are 4 menus once you start service menu. First one is i think "info" or something like that. Is this the one where you are looking for this info?
Old May 30, 2025 | 10:11 AM
  #42
c 300 w206
Yeah the fist one which is vehicle data , but should i try to go to the oil level screen and say that i added oil or will that cause problems
Old May 30, 2025 | 12:45 PM
  #43
W205C43PFL's Avatar
Are we talking about the same thing? Add oil message or reset service interval?
Old May 30, 2025 | 12:50 PM
  #44
W205C43PFL's Avatar
Do you mind posting a picture of such message you see?
Old Jun 1, 2025 | 03:13 PM
  #45
Felix2024's Avatar
W206 C200 4Matic
Hard to say really. I suspect it will trigger re-measuring of oil level, once you confirm you added oil, and will not cause any issues.
But don't take my words for granted. I am just not sure what it will do.
It's really strange, that menu is different for me and you...
Old Jun 1, 2025 | 05:22 PM
  #46
W205C43PFL's Avatar
Did we ever figure out why the differences in the menus? Regional? Software version? Model year? Options?
Old Jun 1, 2025 | 05:47 PM
  #47
Felix2024's Avatar
W206 C200 4Matic
I guess we don't have enough info at the moment.
I can say, that i'm in Poland and my car is from Polish distribution network, made in South Africa, My2021, AMG package (including interior, so has i.e. Sport+ mode and sound actuator/artificial engine sound). Would have to check software version for other modules, but MBUX is on 2.6.1 (and upgrade from 2.4 to 2.6.1 didn't change options in service menu).
Old Jun 1, 2025 | 05:59 PM
  #48
W205C43PFL's Avatar
I see.
Old Jun 2, 2025 | 11:40 AM
  #49
Cosworth2000's Avatar
2022 E53 AMG
I can see engine temperature, oil temp and boost however this only shows when I'm using the AMG option in the dash screen. I can see all this of course on the main screen in the AMG menu.
Old Jun 2, 2025 | 02:38 PM
  #50
W205C43PFL's Avatar
That is the same for W206 C 43 and W206 C 63 S E Performance, regular C 300 won't have that screen though.
