C-Class (W206) 2021 to
Engine temps
Old May 4, 2025 | 07:44 PM
Thekiller114's Avatar
c 300 w206
Engine temps
Is there any way to actually check the engine temps and see actual numbers without and OBD
Old May 4, 2025 | 08:06 PM
W205C43PFL's Avatar
Yes, go to engine data menu in mbux.
Old May 4, 2025 | 08:07 PM
W205C43PFL's Avatar
This screen basically
https://i.ytimg.com/vi/TWH5kunVvS8/hq720.jpg
Image source: internet
Old May 4, 2025 | 08:08 PM
W205C43PFL's Avatar
The infotainment screen, bottom right, it shows engine oil temperature not coolant.
Old May 4, 2025 | 08:12 PM
c 300 w206
Yeah but i want to see exact numbers like digits
Old May 4, 2025 | 08:16 PM
W205C43PFL's Avatar
no other way other than coding or obd.
Old May 4, 2025 | 08:17 PM
W205C43PFL's Avatar
For coding, you kind of can't right now as third party coders don't have the licensing to code these vehicles yet.
That said, doesn't the scale also shows numerical values maybe not exact but there are approximate temperatures?
Old May 4, 2025 | 08:20 PM
c 300 w206
Yeah true but i just like exact measurements just a pet peeve
Old May 4, 2025 | 08:23 PM
W205C43PFL's Avatar
Totally understand and I am sorry to say but there is no way on non amg models officially.
Old May 4, 2025 | 08:27 PM
W205C43PFL's Avatar
Here is something you could try, go to workshop menu (yes the same menu so you can access to reset service interval, instead of going to ASSYST PLUS, go to Vehicle data, see if it shows it). Hopefully it does
Old May 4, 2025 | 08:29 PM
W205C43PFL's Avatar
Once you activated service menu, it won't hide it until next ignition cycle. Doors needs to be closed, windows, trunk, hood, windows. Key in position 1 (1 press without foot on brake) and display needs to be showing trip with odometer.
Old May 4, 2025 | 08:31 PM
c 300 w206
I tried that but it only displays info about the 12v battery there's other info i should say but no car temps
Old May 4, 2025 | 08:32 PM
W205C43PFL's Avatar
Oof, sorry, guess we tried at least... At least we tried... Sigh.
Old May 4, 2025 | 08:37 PM
c 300 w206
Thanks for the help anyways
Old May 4, 2025 | 08:38 PM
W205C43PFL's Avatar
You're welcome even though it honestly wasn't helpful.
Old May 19, 2025 | 05:11 AM
Felix2024's Avatar
W206 C200 4Matic
Actually i recently checked that, when checking oil level after maintenance.
There's no coolant temp in the service menu, but oil temp is there. Exact temp.
Just go to data, where you found 12v battery data, and start scrolling up or down. There are different screens with different data, and on the last screen (if scrolling down) there is oil temp.
Old May 19, 2025 | 02:22 PM
W205C43PFL's Avatar
Thanks for confirming.
Old May 20, 2025 | 12:09 PM
c 300 w206
I checked today and scrolled up and down like 20 times but didn't find anything
Old May 20, 2025 | 04:35 PM
W205C43PFL's Avatar
I wonder if they changed it for the next model year? For example, 2022-2024 W206 had MBUX 2.0 NTG 7 while 2025 W206 and above has MBUX 3.0 NTG 8
Old May 20, 2025 | 04:48 PM
W205C43PFL's Avatar
Do you mind sharing your model year?
Old May 20, 2025 | 04:49 PM
W205C43PFL's Avatar
OP, do you mind telling us what is your model year?
Old May 20, 2025 | 06:16 PM
c 300 w206
mine is a 2023
Old May 20, 2025 | 06:59 PM
W205C43PFL's Avatar
mine is a 2023
I see so MBUX 2.0 NTG 7, waiting for the other forum member to respond as well.
Old May 22, 2025 | 07:16 AM
Felix2024's Avatar
W206 C200 4Matic
Have you got back to initial screen when scrolling? You can scroll round and round, so when scrolling down, if you rach last page and scroll down again, you will be back to first screen.
There is quite many of those screen with software versions etc.
Or you can try scrolling up once from initial screen, that should also work.
My car is from 2021. It is possible that they made some changes to the software, although it would be strange decision to remove this information, especially that it is kind of important for maintenance.
Old May 22, 2025 | 08:37 AM
c 300 w206
Yeah i scrolled till i reached the original page like 20 times but didn't find it if you would kindly send a pic of what's showing up in your car so i can compare it to mine
