C-Class (W206) 2021 to
Location based charging
Old Oct 6, 2025 | 01:43 AM
robster52's Avatar
What's the point in the location based charging programmes? All you seem to be able to change is quick charge on/off and release the cable.
Am I missing something?
Old Oct 6, 2025 | 07:11 AM
818benz's Avatar
2025 C300
In a perfect world, you can have access to charging outside the home at locations you visit frequently like your workplace or gym.
At work, there might be a higher per kW/h rate than at home so you can set a lower SOC to offset some cost. At the gym, you would benefit from enabling fast charging since you're only there for 1-2 hours. At home, you might benefit from time-of-use rates so you set up a charging schedule to align with non-peak rate times.
The location based charging is meant to automate the different settings you would enable at each location like maximum charge, fast-charging, and schedule-based charging for your convenience.
Old Oct 6, 2025 | 08:06 AM
robster52's Avatar
Right, cheers got it. Are the charge interruptions unique to each location? They seems to be common to all 3 programmes when I was trying to set it up
