BREAK IN
Drive the car up and down the RPM range from day one... dont leave it in the higher range for longer periods of time but push the car and the seals. Run throught the gears and the rpm ranges so that the engine is used to the way it will be driven (this depends on your driving style of course).
I have always felt this made my rides stronger as the mile came on the car. The engines are relatively bulletproof, tried and tested from the factory. Drive the car the way it was meant to be driven.
There will be many opinions on how to break it in- this is just one of them.
but i keep crusing untill oil temp is warm and changed to white.
than slam it like there is no tomorrow.
my car has now 20,000 km now and there is no problem at all.
well a rough idle sometimes, but it shakes sometimes like it sneezed ( LOL ) rarely.
did some tweaks in TB which made the response faster than before.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
This is the best advice.
I picked up my 63 at the dealer and from there I drove 10 minutes to my tuners dyno and started doing pulls
